Top 5 Features list for V3 !
 1-10  …  71-90  91-110  111-130  131-150  151-170  …  431-442
3628.111 In reply to 3628.109
Hi Steve, that could potentially work for curves, but for surfaces the structure of a NURBS model can be very different than how polygon mesh geometry is structured and that generally means that there isn't really a direct way to use the exact same tools that you would use with polygon meshes.
A NURBS model can be built out of "trimmed surfaces" - this is where there is an underlying surface that then has trim curves on it which mark different areas of the surface as inactive or holes. This means that there may not really be any correspondence between the surface control points that you would yank around and a particular edge - it's very different than in a polygon modeler since in a polygon modeler an edge or point that you see in the model can be pulled around and it pulls the surface too because surfaces in the poly modeler (polygon faces) are fundamentally defined as going through those points and through those edges.
Here's a bit more description of a "trimmed surface" - here I have a surface:
Now if I turn on control points for that surface, you can see that there is an underlying surface that is just 1 rectangular surface with 4 corner control points in it:
It's those 4 control points that actually define the overall shape of the surface, all the edges that you see are all trim curves that are defining which regions of the surface are inactive.
But the trim curves are just markers - they do not themselves define the shape of the surface, that comes only from the surface control points.
So that means that it does not really make sense for example to try and grab this edge curve here and try to move it around (like pull it up or down in Z for example):
The thing that can be freely pushed around is the 4 outer surface control points, not that marker trim curve that is just living on the surface.
So just in general this kind of structure with trim curves just does not work the same way as a polygon mesh structure as far as squishing individual points of things around.
There is some more description of how trim edges and "underlying surfaces" work here:
http://moi3d.com/faq#Q:_Why_does_show_points_work_for_some_objects_but_not_others.3F
So you may ask - why use this structure at all if it doesn't allow for doing the same things as a polygon mesh?
Well, the answer is that this very same structure is the reason why Boolean operations works so much better with NURBS than with polygons - in a NURBS model when you do a Boolean the surfaces of the models actually remain exactly the same and only new trim curves are calculated to mark different regions of them as being inactive. This fundamentally helps keep things a lot more under control because your model stays in large logical sheets - when doing a Boolean operation in a polygon modeler the poly modeling program has to fragment things into a zillion little tiny sub surface faces because it doesn't have this way to have just a zone on an existing piece to be marked as being a hole...
This difference in structure is basically why there is a much different base toolset in a NURBS modeler versus a polygon modeler. But that difference is kind of what makes NURBS useful as a companion to a poly modeler, because it has a much different set of both strengths and weaknesses...
EDITED: 28 Apr 2011 by MICHAEL GIBSON
3628.112 In reply to 3628.111
Thanks very much for your detailed explaination.
I guess our only way to affect a mesh/nurbs object globally then is to use a deformer (bend, etc)? When I mentioned falloffs I was thinking of the control points on a sphere , where you have multiple points and applying a fall off to that would help produce certain shapes.
I do have question/feature request if its possible.... Would it be possible to increase the control points on an object (such as a plane) or a cube, etc. When creating a cube or a shere could we have an option to specify the number of control points it consists of? If an object has already been created could we increase the number of control points via a properties panel?
Thanks again
Steve
3628.113
Some noteworthy people have already mentioned these, but I'll reiterate since I think it's important.
1. Variable Fillet
2. Continuity options in more of the existing tools.
Those two alone would eliminate my need to use rhino every so often, and I think it would entice a lot of people to jump over to MoI.
3628.114 In reply to 3628.112
Hi Steve,
Yeah, and that actually involves some fairly fancy stuff like automatically rebuilding surfaces to have as many control points in them to flex to the amount of bending that is happening. But there has been some support for that kind of thing in the new release of the geometry library that MoI uses, so there is a pretty good chance at being able to get something going for that kind of deformation. I'll know more about this kind of deformation when I get a chance to dig into it in v3.
> certain shapes.
Yeah, it would actually work in this case - when you have a simple sphere that has not been booleaned with anything, then it is an "untrimmed surface" - one where the trim curves are only around the natural boundary of the surface.
Those can be handled by pulling control points around like you would with a polygon mesh. But the problem is that once you boolean it with something else then the resulting booleaned object is made up of various trimmed surfaces and you can't easily pull any of those control points around anymore without tearing open holes between the different trimmed pieces.
So because it's kind of limited to certain special cases, this area of surface control point manipulation is kind of underdeveloped in MoI right now, I wanted to focus more effort initially in areas where NURBS have their greatest advantages compared to poly modeling, like boolean operations.
Yes, this will be possible - I do expect to flush out some of the surface control point functions in MoI as time goes on and this would be part of that.
3628.115
If we ever get falloff tools I would like them to be ala Michael Gibson or at list ala Alias ;) http://www.youtube.com/watch?feature=player_embedded&v=3z5VyVuKqTA#at=50
http://wikihelp.autodesk.com/Alias/enu/2012/Help/0061-What's_N61/0071-Modeling71/0080-Direct_S80
Michael could something like that be possible with the Solid++ deformation engine?
3628.116 In reply to 3628.115
Hi adam,
I'm not really sure yet since I have not had a chance to dig into it in detail yet.
But I think it's possible that a kind of deform that is limited to only a small localized area is not really a great fit with the deform mechanism.
It's probably going to be more likely for stuff that warps the whole object.
But we'll see...
- michael
3628.117
Michael ...
I would really like to be able to print directly from MoI ... or convert to pdf, once we have text and dimensions.
I know we can use SimLab Composer to do 3d pdf and that is great but I need to be able to print to 2d also.
So I hope that will be part of Ver 3
cheers,
eric
3628.118
Why support textures? This program is a modeler and let it remain so! Extra instruments will only interfere with the work. And with the texture units can work in other programs.
Michael, good luck!
3628.119
The main things I would like to see are:
Variable radius fillets
Continuity options for patches
3628.120 In reply to 3628.119
Any chance for more file types for import/export?
8 GB RAM, ATi Radeon HD 3870
3628.121 In reply to 3628.120
Hi Nick,
Sure, it's possible. What formats did you have in mind?
Right now DXF, SVG, and PDF are kind of at the top of the list.
3628.122 In reply to 3628.121
Import - *.wrl, *.dwg (3D data), pdf underlay
Export - 3D pdf, *.dwg, *.bip (for us Alibre users :-) )
Other than these I don't really have a "top 5." Even these are a "would be nice" feature and not something I would quit using MoI over.
Stuff that I would have in a top 5 you have already hinted at working on (mainly UI stuff).
Thanks!
3628.123 In reply to 3628.122
Hi Nick, so there are some various difficulties with several of those formats.
.wrl is a polygon based format, things like a sphere in a .wrl file are made up of a lot of little triangular facets and not an actual smooth sphere surface. That's a pretty different type of data structure than the NURBS surfaces that MoI works with.
.dwg is a proprietary format from Autodesk which is not very easy to deal with without using some special kinds of libraries. There is a companion format called DXF which is actually documented (for 2D stuff anyway, NURBS solids are not documented).
.bip I don't think is publicly documented. I think it is a text file format so it could be possible to figure it out but having an official public document that describes the file structure helps a lot when trying to make an exporter for that format.
.bip is pretty specific to just one particular rendering program - just in general with MoI it's more feasible for me to work on file formats that tend to be used by a variety of different programs for file transfer instead of ones that are specific to just one program. OBJ format already contains the exact same kind of data that would go into a .bip file...
3628.124 In reply to 3628.123
Thanks, like I said these are kind "nice to have" things, but no real biggie. I understand DXF, but find DWG to be more robust/feature rich for 3D and is of course an industry standard (despite being proprietary). Maybe I could amend this and request 3D DWF instead?
The API, specification, and toolkit are freely available. http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=5801732
Thanks for listening,
Nick
3628.125 In reply to 3628.124
Hi Nick, that's interesting that there is a toolkit available for DWF, I didn't know that existed.
What would be the benefit to you in having DWF output from MoI - is there a particular program that can only read in DWF format stuff and not any other formats?
I'm not really all that familiar with DWF myself - I guess it is basically trying to do the same job as PDF though? What are the advantages that you see compared to PDF?
I took a quick glance at it, and in some ways it seems to be a kind of complex file format, in that there are kind of various totally different sub formats within it, like 3D data is contained in a completely different kind of internal document than 2D data, etc... PDF is kind of like that as well though, with 3D PDF content being basically a completely different kind of structure kind of tacked on.
3628.126 In reply to 3628.125
You are correct with the two different froms for 2D vs. 3D. The reason for that is the 2D data (in some sort of xml format) is readable by the Microsoft XPS viewer which is included with Windows, so basically any windows (Vista +) computer can read 2D DWF data without any other program installed. This ability is limited to the DWFx format (which is kind of the new defacto).
The advantages of DWF over pdf are file size, and a more robust 3D viewer in addition to free markup tools (Adsk Design Review). DWF really is a more CAD-centric format than PDF. I *think* 3D pdf was kind of a reaction to DWF and is now in the hands of Tetra 4D (?) instead of Adobe. It's a good way to hand over a design for review without actually handing over the design. There aren't any specific programs (besides Design Review) that only accept DWF that I am aware of.
It has it's uses, but is not going to be a "Wow, I'm sold!" feature.
I attached a quick demo dwf (just some basic shapes). Note: only 2D stuff will show in xps viewer.
3628.127 In reply to 3628.126
Hi Nick, I see - that could definitely be useful as a viewing mechanism.
That kind of thing is probably more on the back burner as compared to adding formats that are more about transferring data to be used by other CAD or illustration programs though.
2D PDF being generally similar in functionality but kind of more widespread would probably come first before DWF.
3628.128 In reply to 3628.127
The only other thing - and I don't know how it compares to 3D pdf, but the 3D data can be extracted. I have been playing on and off with IMSI DoubleCAD and it (probably TurboCAD as well) actually imports dwf 3D models and allows the use/editing of those models. Of course accuracy is compromised when that is done.
That's kind of what I figured. I have been trying for years to get clients to switch to dwf the file sizes are almost half of the same pdf (2D vs. 2D). I don't have or know of any programs that do both 3D pdf and 3D dwf so I can't compare 3D files.
3628.129 In reply to 3628.127
Michael,
I have two request and unfortunately they are not low-hanging fruit. One I have asked about in the past, and I am sure others have also, which is a Mac version.
The other request will probably illustrate a severe lack of knowledge on my part, but I would like a way to convert my beautiful N-gon mesh to quads. I like how quickly I can make a model in MOI, but if I import the mesh as a obj they are unusable in ZBrush for sculpting.
This turns out to be such problem that I recently bought Modo, which allows me to add edge loops on my SubD models to have a nice quad mesh.
I am not sure how tough it would be to reduce the amount of tris generated during export, but it would help if I only had to make a few modifications in Modo or Maya, instead of having to retopo the whole mesh.
Regards,
Paul
3628.130 In reply to 3628.129
Hi Paul, yeah unfortunately both of those are quite difficult things.
I am making some progress on converting the UI to a system that will be more feasible to run on other operating systems, so that's a step towards that but there may be several other big steps needed as well. So I'm not sure when that will actually happen. Meanwhile it is possible to run MoI on your Mac right now using the Parallels or VMWare virtualization systems.
That's a much more difficult problem, since it would require a very different meshing mechanism, basically it would need to tile some kinds of complex outlines with a small pattern of quads. See these previous posts for some more description:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1244.48
http://moi3d.com/forum/index.php?webtag=MOI&msg=3854.15
http://moi3d.com/forum/index.php?webtag=MOI&msg=2451.50
http://moi3d.com/forum/index.php?webtag=MOI&msg=3869.64
You can get an export for sculpting in ZBrush using some settings to divide the mesh into small pieces - also don't export using n-gons since ZBrush does not like to deal with n-gons, use "Output: Quads & Triangles" instead.
For dividing the mesh, enter a distance value in the "Divide larger than" setting to subdivide the mesh into little fragments, that can then be manipulated in ZBrush.
See here for some examples:
http://moi3d.com/forum/index.php?webtag=MOI&msg=804.26
http://moi3d.com/forum/index.php?webtag=MOI&msg=2833.5
Show messages:  1-10  …  51-70  71-90  91-110  111-130  131-150  151-170  171-190  …  431-442
