V2 is released!
 1-19  20-39  40-58
3573.20 In reply to 3573.19
Hi, Michael, I'm just writing to let you know that this page needs to be updated to version 2 as well. Is this yours? It showed up on a google search on moi 3d tutorials. It sure looks like it should be yours if it isn't.
http://www.moi3dasia.com/download.php
3573.21 In reply to 3573.20
Hi omac12, thanks for the heads up!
That page is not actually mine, but it belongs to a company that I work with that handles distribution of MoI in Asia.
It will take a bit before all that kind of stuff gets updated.
Re: Educational discount versions
It will probably take until next week sometime before the v2 educational discount versions are ready, I need to do some setup work with Studica for those and it is currently a holiday weekend here in the US so that will likely delay things a bit on that front.
I also had a question from someone who had the v1 edu version but was no longer a student, they asked if they could use the current (non-edu) v2 upgrade version, and the answer is yes - the v2 upgrade version requires a v1 license key in addition to the v2 one that you get but any v1 license key will be valid for the upgrade including v1 edu licenses.
For people who are still students, I do plan on having an edu v2 upgrade version as well, that will be less expensive (how much is still not set yet, waiting to hear back from Studica on that) than the regular v2 upgrade version.
The script copier utility for the v2 release version is attached here.
If you run this utility it will copy plugins that were installed in the commands folder in v1 into v2's commands folder so that they will also be installed in v2.
3573.24 In reply to 3573.23
Hi, Michael,
Congratulations on the release of V2!!
Unfortunately, no time for modeling recently due to work and various other commitments, but bought and downloaded V2 as soon as I saw the announcement :-)
Looking forward to new goodies in V3 after you have had a break.
Tony
(aka HamSoles)
3573.25 In reply to 3573.24
Announcement from Deelip.com : http://www.deelip.com/?p=2412
3573.26
Congratulations Michael!!!
Good to see V2 released!!!
does this working in the V2?
A sort of loop selection
Edit : cool :)
script:moi.geometryDatabase.selectLoop();
EDITED: 30 May 2010 by PILOU
3573.28 In reply to 3573.27
Very nice!
It would be great if there would be a tab where all the defined keyboard shortcuts can be opened as list and activated with a mouse click... I always forget what I defined as shortcut and then have to fly to europe, travel by donkey to a remote location, turn a rock, dig 8 ft deep... unearth the treasure chest, open it with the hidden key from under another rock, then open it, take the scroll out, have it deciphered, cross translated, and then studying it to find the correct entry... then go back home... just to find out I forgot what I was looking for... Long story short.... The shortcuts are a pita to use for me ;}. Probably good for someone using MOI often. If not... one forgets so quickly.
Rainer
3573.29 In reply to 3573.1
Thank you Michael:) just placed my order.
3573.30 In reply to 3573.29
< Is there a script copier for V2
A record script? No
Something for copy scripts from V1 to V2: Yes
http://moi3d.com/forum/index.php?webtag=MOI&msg=3573.23
3573.31 In reply to 3573.27
Hi Pilou, yup being able to set up that loop selection on a keyboard shortcut is one of the new things in v2, it looks like you found the script for it already.
There are some details on it in these posts:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3112.22
http://moi3d.com/forum/index.php?webtag=MOI&msg=3112.32
3573.32 In reply to 3573.28
Hi Rainer, yeah I do want to make it easier to set up keyboard shortcuts in the future, it's just one of the many areas that I have not yet had time to focus on.
There is a listing of all the different command names that you can set on a keyboard shortcut available here:
http://moi3d.com/2.0/docs/moi_command_reference11.htm#shortcutkeys
3573.33 In reply to 3573.30
Script copier utility for v2 is available here:
3573.34 In reply to 3573.28
Lemo,
You can also use the plugin Gallery to do this.
3573.35 In reply to 3573.1
Great work! looking forwards to trying all the new features
"Simplicity is the ultimate sophistication"
Leonardo Da Vinci
3573.36
Great work!
Thanks Michael
3573.37
You and MoI are my favourite example how good a software and the support of a company can be!
Thank you so much for all your hard work.
Cheers!
Thomas Helzle
3573.38 In reply to 3573.22
Hi Michael, I did get MoI 1.1 at Studica a few days ago but then v2 came out right afterward, which I didn't expect so soon... But I would like to use the new one, so I decided to get an upgrade. I might have messed things up somewhat because I saw only v1 at Studica, and I just now bought the full upgrade from plimus, thinking maybe Studica would only get v1. This was before I saw your message above. Can that be adjusted?
So I have what appears to be my upgrade license under "supplied license" from the plimus page. I came to the forum initially to see if I am supposed to install the thirty day trial and then enter that number in there or if I will be sent a link to a different installer that I should use. Thank you, --Adrian
3573.39 In reply to 3573.38
Hi Adrian, yes sorry it is going to take a bit more time before the Studica order pages are updated for v2.
There is a different installer for the full version, there isn't any way to "unlock" the trial version.
You should get an automated e-mail when you placed your order, with both your license key and a download link in it to the full version installer.
Please check any "junk" or "spam" mail folders for that e-mail, and if you can't find it please e-mail me at moi@moi3d.com and I will send you back a download link.
The edu version upgrade will be at a reduced cost than the regular upgrade version that you just purchased, so if you would like I can refund your current one if you want to wait and get the edu one when it is ready from Studica.
Show messages:  1-19  20-39  40-58
