Recommended free renderer - An old question, maybe a new answer?
 1-19  20-39  40-59  60-69
3136.40 In reply to 3136.39
Thanks Pilou,
I'll run Cleanup on the 3DS import and then try again.
By the way - re: "... Of course better is export from Moi in SKP ;) "
Is MOI .SKP export a V2.0 feature?
3136.41 In reply to 3136.40
< Is MOI .SKP export a V2.0 feature?
yes! SAT, STP, FBX & SKP export exist in the V2 beta ;)
EDITED: 2 Dec 2009 by PILOU
3136.42
3136.43
DAZ Studio is really nice, especially when you start working with Puppeteer and add on Animate+.
My other recommendation would be Carrara Pro as well.
Ultimately I'm placing my bets on Lightwave CORE, focusing back on Lightwave will allow me to shed Softimage and Cinema 4D - those packages are too expensive to keep up with especially since currently I'm just a hobbyist...
-Will
3136.44 In reply to 3136.38
Argo,
Thanks for posting your DAZ Studio render, I might re-look at this app as sometimes I need something simple and quick. I really like Blender, and Blender with Yaf(a)Ray but I don't always have the time to set up, assign materials, render, tweak - repeat.
- David
3136.45
Would anyone like me to make a tutorial on using Kerkythea and MOI3D?
3136.46 In reply to 3136.44
David
Your welcome :-) DAZ Studio sits well with the "wiring" of my brain. Other than the "Darthvader" (black) UI it sort of reminds me of the MOI process. Of course that just me and as they say: "results may vary".
George
Downloading IR now. I glanced at this previously and then moved to the other programs for whatever reason. I really need to stop taking a butterfly approach to this! Almost spoilt for choice for renderers (all with their own idiosyncrasies).
3136.47 In reply to 3136.45
Phil
Yes :-)
If you can afford the time of course!
3136.48
Hi, all
My example:
Modeled in Moi and rendering in Kerkythea
Great kerkythea software
Marco (marcorhino)
3136.49 In reply to 3136.48
Nice render there, look great for a rendering engine.
how is the interface?
Cold
| Adobe Photoshop CS | Corel CorelDraw Grahics Suite X3 | Daz 3D Bryce 5.5, Carrara 6 Pro, Hexagon 2.5 | Maxon Cinema 4D R8.2 | Moi 3D |
Gallery
3136.50
hi
i think daz3d (intergrated 3delight) is a really nice renderer with some nice plugins (commercial). some tests with vict. 4 - daz aya. I know that would be better results with cinema4d or other applications. But for quick render really nice...
EDITED: 15 Dec 2009 by APOPHIS
3136.51 In reply to 3136.35
(quote from Michael, 3 Dec 2009)
The new 3D PaintBrush app Ralf mentions above seems pretty good! (http://www.3dpaintbrush.com/)
Introductory price = $99
The UI seems nice and actually easy to use.
It can load a 3DM file directly but it does not seem to do a very good job of producing a mesh directly from the NURBS data, but bringing in OBJ files exported from MoI seems to work well with it. It appears to load in all the vertex normals and material information from OBJ files so that is great.
This may end up being the kind of missing link for an inexpensive but easy to use standalone rendering program.
It may possibly be a little too streamlined though, there does not seem to be very many options exposed for tweaking the rendering like anti-aliasing settings, etc... but it seems like you can get a basic result quite easily. I wish there was an option in it to adjust the view rotation to keep the same "upwards" direction while rotating around though.
I would think this would actually go somewhere near the top of the list to check out for getting stuff done easily.
Hm, I've tested this out and it seems ok...
But I can't seemt o get it to render a png with a transparent background...
Anyone know how to do this?
3136.52 In reply to 3136.51
Hi NightCabbage, if nobody here knows the answer you may want to e-mail 3D PaintBrush tech support which seems to be here: support@3dpaintbrush.com
3136.53
Yeah I did that already but they haven't gotten back to me yet.
Just thought someone here might know - given it's a pretty basic feature?
3136.54 In reply to 3136.48
Marco,
How did you get the symbols on the door and on the bumper? I can't figure out how to make that happen in Kerkythea.
Thanks!
Plish
3136.55
I'm surprised no body has mentioned "Rendergin" : http://www.numenus.de/index_en.html
Its not free however it has some unique features worth paying for : Direct NURBS raytracing and global illumination. This means that you don't have to tessellate your models and therefore their rendered form is not approximated/is perfect.
http://www.youtube.com/watch?v=-gGX1GP_d78
It supports MOI's files directly and scene setup is very simple. The only downside I can see so far(keep in mind its still a beta) is slow rendering speed(when soft shadows/reflections are present) and jumpy interface navigation(seems they are down sampling the image too much).
3136.56 In reply to 3136.55
< I'm surprised no body has mentioned "Rendergin"
This was named "Augenblick" before and the creator was in the Moi forum for test his product ;)
http://moi3d.com/forum/messages.php?webtag=MOI&msg=3298.37
EDITED: 8 Jun 2011 by PILOU
I have tested today RenderGin ;)
Seems loading Nurbs have always some problem, some surfaces are not rendered! ;)
it's twice the same symetric objet, on in grey, one in bicolor!
http://piloumaison.weebly.com/uploads/3/6/2/0/3620514/boule1.3dm
EDITED: 9 Jun 2011 by PILOU
3136.58 In reply to 3136.55
Not even near: With 800 Euros for the entry version and 4500 Euros for the professional version, once it leaves beta, according to their resellers' website (http://www.3dcyberdream.com/index.php?mnav=0103&id=21), this is not a software that I would categorise under "easy on the budget".
From: Ambimind : "The only downside [...] is slow rendering speed".
We have fidderent, eh, different priorities, obviously ;)
Edit i: It seems one needs the pro version to render nurbs surfaces. I guess I will stay with exporting obj format for a loooong time. And with my trusted Thea render @ 300 Euros.
EDITED: 9 Jun 2011 by DITTO
3136.59 In reply to 3136.56
Thanks Pilou.
Unfortunately your right, there are some problem with the import system.
Show messages:  1-19  20-39  40-59  60-69
