Strange Sweep Ends
 1-16  17-22
2879.17 In reply to 2879.15
Cabbage,
A good tip to remember with your solids also is the "Seam edge". When you create a sold to use, before you do anything, try to have that seam edge rotated out of the way of other operations. It's not a must, but in certain circumstances having 2 seam edges exactly graze along each other can cause problems. Like if you create a sphere and align some other cutting object directly on that sphere seam edge, then try to fillet that edge, you "could/may" experience poor results.
Again, just a good habit to develope when starting out.
2879.18 In reply to 2879.17
Here's Cabbages Engine file with the Exaust turned into solids and booleaned on to the engine. I tried to disable history on all objects from the beginning. If I select just the face of one of the exausts and run shell, it appears to try and shell All the exausts. If I select all exaust faces and run shell I get a good reslt ( .1 as the defined thickness).
Seems like something is up with his model? Possibly I missed an area I should have hit disable history? I started with the model he posted.
I ran planar on the whole group of exausts to cap them off. Perhaps if I planared them seperatly. I can fool a bit more also.
2879.19
Thanks for the reply!
What's Shell?
Ok so I figured that part of my problem was because I wasn't using solid objects (for the exhausts?)
And I figured out that another of my problems was that I was trying to boolean some things together when I should have been joining.
So you boolean intersecting solid objects, and you join touching lines.
Here's my new version :D
engine3.3dm
Maybe someone could check it out and see if it's done right?
2879.20 In reply to 2879.15
Hi NightCabbage,
> I guess I'm just trying to minimise my use of booleans,
> because in poly modellers booleans are horrible and don't
> work half the time.
> But if I can rely on the boolean in Moi to work all the time,
> then that sounds great :)
Yeah, that's one of the major differences between NURBS modeling and polygon modeling - booleans are much more robust and you usually focus on using them as a primary method of construction in NURBS modeling.
2879.21 In reply to 2879.19
Hi NightCabbage,
> What's Shell?
There's some info in the help file:
http://moi3d.com/1.0/docs/moi_command_reference7.htm#shell
The help file reference index is available here for browsing:
http://moi3d.com/1.0/docs/moi_command_reference.htm, it's a good place to look if you want to get some general info on how a particular command works.
Yeah, usually for doing the booleans you will want to be working with solid objects instead of trying to combine a solid with a surface like you had in this case.
Normally if you do a Loft between 2 circles you should get a solid though, unless you turned off the "cap ends" option?
Otherwise, you can select them now and run Construct / Planar to cap the ends off now, or like Burr mentioned use Construct / Shell if you want to thicken the surface into a solid which will be kind of like a hollowed out cone.
Yup!
You can also use join on surfaces as well, if you have 2 surfaces that are touching at a common edge, then join will glue them together and they will then have a joined edge between them.
When you have a set of surfaces that have all edges joined to another edge, then that is what makes a solid.
It can be convenient to work with solids, because the booleans are set up to work on volumes, and determine which pieces to keep and discard based on that.
Seems to look all ship-shape to me!
To make a more complex model you just keep doing what you've been doing and adding more and more pieces.
2879.22
Thank you so much for your patience! :)
(ah, so shell is under offset - cool, I've been looking for a tool that does that!)
Show messages:  1-16  17-22
