missing something
All  1-4  5-6
2851.5 In reply to 2851.4
Hi Eric, yeah MoI won't create the line if you just "hover" the mouse over a point, you need to press and hold down the mouse and drag out a line if you want one.
Most other systems use the hovering method.
The hover method works pretty nice with very simple and sparse drawings, but once things get a bit more complex it can tend to fill your screen with so many snap zones that you no longer have any freedom of movement for placing points.
So that's one reason why MoI uses that "press and drag" gesture with the mouse to activate a line rather than just hovering. That way you have more control over when they are activated.
There is another reason though too, which is that MoI's method allows you to define a line by 2 points by where you started the drag from and where you released the mouse at. This allows for various additional kinds of snaps, like getting the point half-way (or at 1/3 increments, etc..) between any 2 existing points, mirroring a point to the other side of a centerline, capturing a distance and applying it to a different location, and many others.
See here for some more information on how all that works:
http://moi3d.com/1.0/docs/moi_command_reference10.htm#constructionlines
Much of that functionality is not possible with lines created in the "hover" type system since that makes a line that radiates out from only a single base point and does not have a distance component to it.
2851.6 In reply to 2851.5
Hi Michael ...
Yes, that makes a lot of sense ... and I have experienced exactly what you are talking about. Logically your approach sounds better and more reliable ... I just have to get used to it.
As MoI has been developing I have been switching back and forth quite a bit but now that MoI is more mature, or at least more suited for my needs, I will be switching less and less for modeling. I really do like working with MoI.
I will probably be using other software for quite awhile, though, as a lot of my work flow includes 2d dimensioned drawings with line types ... and architectural renderings, too.
cheers,
eric
Show messages: All  1-4  5-6
