Close Surface
All  1-9  10-15
2623.10 In reply to 2623.8
Hi Anis,
> You can try fillet with "const dist" option on attached 3dm.
Thanks - I can repeat the failure when doing the edge-based fillet after assembling those pieces into a solid, but if you do a surface/surface fillet on the original pieces you have it seems to work ok.
The way you have that file structured currently with separate surfaces, it is actually faster in this case to do a surface/surface fillet anyway, your surfaces will be all ready to join immediately after the fillet that way.
A surface/surface fillet is when you select 2 individual surfaces (which is actually how you have the file arranged at the moment), and then run Fillet, rather than selecting pieces like edges of a joined-together object.
Surface/surface fillets can succeed in places where the edge-based ones may fail.
Here is a quick demo of getting a constant distance fillet on your file by using surface/surface fillet:
2623.11 In reply to 2623.10
Hello Michael....
Sometimes I forgot that we can use that method in MoI.
How about this :
If there are some sketch appear, the prompt should be :
select sketch, edge or faces to fillet.
2623.12 In reply to 2623.11
Hi Anis,
No, that's probably not a good idea since it is also possible to select whole objects as well.
For example draw a solid box, then select the box (no edges or face sub-object selection, just the whole box by a single click) and you can now run Fillet to round all edges of the box.
In Fillet you can select either 2 separate curves, or a multi-segment curve, or edges, or faces, or 2 independent surfaces, or an entire multi-surface joined object.
That's a lot of different things, it would make the prompt too long.
If you need to do a lot of filleting it is better to just make sure to learn how it works.
If you need a reminder, this behavior is covered in the Fillet entry in the help file:
http://moi3d.com/1.0/docs/moi_command_reference7.htm#Construct_Fillet
2623.13 In reply to 2623.12
Michael...
Sometimes we are forgot about what object that should selected under an active command.
Maybe in the future there will be another idea to make user "automatically" know what object should be select by a prompt / warning / sign.
2623.14 In reply to 2623.13
"tooltips" could be added with an option to turn them on/off, but certainly not very high on the list.
2623.15 In reply to 2623.13
Hi Anis,
Some commands that can take a wide variety of different objects will generally not list every possible thing, that would just make for too long and confusing of a prompt.
When there are a lot of different possibilities, then it will just say "objects" - that is intentional to keep the prompts shorter and easier to read.
For stages of a command where there is more specific input required, then in those situations it would be more likely to have it mentioned - for example with Network the prompt says "Select curves for network".
I'd actually recommend that you pick the objects you want to work on before you even run the command, and that prompt will not show at all in that case. Picking objects before the command generally saves a step since you don't have to hit "Done" (or right-click) to indicate that you are finished picking.
Show messages: All  1-9  10-15
