V2 beta Apr-12-2009 available now
 1-9  …  70-89  90-109  110-129  130-149  150-169  …  210-216
2570.110 In reply to 2570.108
Hi Burr, also one other detail - one reason why the list of styles does not get compacted to not show the "empty" ones is so that you can still use the shortcut of clicking on a style's swatch to assign selected objects to it, or right-click to set it as the active style that will be used for a newly drawn object.
If the styles list did not show styles with no objects on them, then those shortcuts would not be available to use on a style until you placed an object on it first.
However, in the future at some point I think it would make sense to have some kind of filtering mechanism that you could adjust to have some control over what was displayed there so you would have the option to only show occupied ones. But it will probably be a while before that happens.
2570.111 In reply to 2570.106
>>>>>I think it would be better if you could double click on the style name to change its name, or on the colour to change its colour.
I just found that if you have a selected item and double click on a style, it will change that item to that style.
Part of what you asked I think.
[EDIT] Looks like Michael just posted that answer as well [EDIT]
2570.112 In reply to 2570.111
Hi Burr,
Yup, that is a shortcut way to assign a style to the selected objects.
You don't even have to double-click, just a single click will do it.
You can double click if you want though, it will just set it to that style twice in a row... ;)
But I think okapi was talking about something a bit different - about some quicker way to edit the style itself to have a different color than it currently has.
2570.113 In reply to 2570.112
You can double click if you want though, it will just set it to that style twice in a row... ;)>>>>
All the time and effort you put in to keep the UI clean....And I just add clicks at will!!! Go figure.
2570.114
I noticed that if you create a feature on an object, that feature takes on the current active style, e.g. if a cylinder has style=green and the active style is red and you apply a fillet to the cylinder the fillet takes on style=red, I would prefer that the fillet inherit the style of that cylinder no matter what colour is active, when working on an object I don't want to always check if I have the same colour active.
2570.115 In reply to 2570.109
Are you really changing your styles very frequently? I mean is it something that you go to mess with every few minutes?
It is generally not efficient to try and highly optimize operations that you don't need to do very frequently, in fact it can be kind of good to have those kind of non-optimized because it helps to leave the optimized spots for things that you may want to do several times a minute instead, like hide/show.
So it is not necessarily a priority to lower the number of steps for every single action.
you are right, I don't think I will be changing styles very often, and I can work with the system as it is.
I think I am changing styles often now because it is a new feature and I am trying it out ! (please stop adding new features, it hurts the workflow ! just joking..)
I agree that it is much more important to get the exports etc... working properly.
However once you have a chance to improve it, it would be good to get a more streamlined way of editing styles as mentioned.
I think a drop down arrow would work well too.
Thanks for all your hard work!
2570.116 In reply to 2570.107
""The ones that have objects on them have black text, ones with no objects have gray text""
That's the part that I didn't catch!
Marc
Message 2570.117 deleted 16 Apr 2009 by PAOLOLOBBIA
2570.118 In reply to 2570.103
very good to hear that you will try the tabs without the legs - if that doesn't work, I guess the shorter version from Marcs screen would do well also.
I don't know about others, but somehow I don't see it as such a huge problem to be able to differenciate the tabs from the main browser label. Since your solution is so flexible, the heading is not so extremely important for me, each tab stands for himself in a way. I guess this is why I felt the current one to be a overly strong division - and as soon as the tabs are opened, the problem solves itself anyway, since the sub-stuff is indented much more.
Whatever you will come up with - I like it a lot.
And no, I wasn't talking about inside mode. I tried with about ~40 named objects and then in adjacent mode the browser was pretty full screen ;-)
On that large screen I can spare some space ;-) but inside is very slick for less objects.
Yeah, I also wasn't sure about automatic naming. I just realized how used to it I am from software like XSI etc.
I agree that it can be annoying at times and meaningless.
You do a perfect job of rethinking some of the so-called standards for us!
Thank you very much!
Thomas Helzle
2570.119
When i copy/paste one object into rhino,
all the styles are pasted as well.
I prefer to copy only the style in which the
object belongs to.
Does it possible to "lock" something in the Browser?
2570.121 In reply to 2570.120
Not yet.
Does "transparency" is on the list?
for example
50% visibility of a group of objects for work on a new object
2570.123 In reply to 2570.122
> Does "transparency" is on the list? for example
That is something that I would like to add in the future, but I do not expect to have that for the v2 release though.
2570.124
Nice work Michael !
The AI import with files from Photoshop works great now. I've also been able to use the offset command in situations where it would have failed in previous versions. Really cool.
I like the way you've organized the browser. Just one question there : custom styles are saved in the project but if I start a new file, my custom styles are not available anymore. Is there any way to keep them so I can create a few styles that I like and reuse them in all my projects ?
Any chance to have variable fillets in V.2 (or at least on the top of the list when you will start to work on the V.3 beta) ?
Thanks a lot for this beta.
Edit : By the way, can you explain this (from the release notes) : "or by using the new typed-in command launcher." ?
- Schbeurd
2570.125 In reply to 2570.124
Hi Schbeurd, thanks! I'm glad that the AI import works again for you.
Yup, to do this make a .3dm file with the styles set up the way you want, then specify that file as the startup template under Options / General / Template file.
That will then load that file when MoI starts or when you do a File/New, so that you can start a new scene up with that stuff in it initially.
There is still one situation where the "hard defaults" get used, which is when you read in a file written by a previous version of MoI which only made a single style/layer in them. At the moment that situation won't bring in your template file styles but I should be able to tune it up to do that.
> the V.3 beta) ?
It's not likely to make it for v2. I would like to make it in for V3 but it's a bit early yet to know what will happen immediately there, I don't really have it all planned out yet.
That's referring to this other new feature covered later in the list:
Enable mini command-line entry by typing in a command name into the XYZ coordinate entry box. Type <tab>, then the command name, then <enter> as an alternate way to execute a command or script file.
Thanks!
2570.126 In reply to 2570.119
Hi Paolo,
> object belongs to.
Yup, I will be tuning it up to behave like this for the next beta release.
2570.127 In reply to 2570.126
Thanks Michael,
I hope you did'nt get stressed these view days
answering al those questions.
I purchased T-Splines,wich has wonderfull features
and after playing with it, i realised that Moi is still strong
in putting up a fast Sketch.
And the beta crashes several times.
So for a long time i will support Moi.
2570.128
Hi Michael, some kind of weird bug in the new beta. All I did is cut that face out of the loft shape behind it.
2570.129 In reply to 2570.128
Hi Val - are you talking about the control points of the trimmed face being larger than the edges?
That's actually a normal thing if you trim a face from a larger surface, the original surface is still a part of that face, it is the "underlying surface", there are just new trim curves on it.
There is some description on how underlying surfaces work here.
It is possible to shrink the underlying surface down if you want - to do that set up a shortcut key with this as the command: ShrinkTrimmedSrf
Then if you select that face and hit that shortcut key, that will shrink down the underlying surface to the trimming boundaries.
Please let me know if you are talking about something else other than that...
Show messages:  1-9  …  50-69  70-89  90-109  110-129  130-149  150-169  170-189  …  210-216
