Deform
 1-11  12-23
Bending is not more in the spirit of Polygons Modelers?
As propagate is in Nurbs spirit, you should not need to make that!
If yes, it's because your start concept was not enough elaborate :)
About deform in box modeler
see this teaser of Fredo6 for a new bend function in Google Sketchup ;)
Video : http://www.sketchucation.com/forums/scf/download/file.php?id=23992 2 megas avi format
2487.14 In reply to 2487.12
I don't really agree but maybe I don't understand you.
It's often easier to work on some details on a '2d' plane/view and then bend it, that dealing with a curved surface.
Was maybe thinking to tire pattern for example ... or any kind of engraving job.
2487.15 In reply to 2487.14
These kinds of tools are great for the creative guy. Sometimes a project can have no plan....Then let the mind flow...
I would love to see this tool show up more often also. Maybe when MoI is more mature and Michael has creative time he could explore some of the "off the beaten path" tools for addition.
2487.16 In reply to 2487.14
@PAQ
< Was maybe thinking to tire pattern for example ... or any kind of engraving job
Ah oui? :)
2487.17 In reply to 2487.15
And here I thought that was exactly what he is doing :)
eric
2487.18 In reply to 2487.14
There is no doubt that it can be useful for a variety of different things.
But it does tend to go more naturally with a mesh modeler though, mainly because it is much easier to make it work well with mesh geometry.
With a mesh object if you move the control points of the mesh around, all the edges and faces move right along with it, there isn't any concept of there being an "underlying surface" that has separate trim edge structures on it like there is with a NURBS model.
With a NURBS model, you can't just move all the control points of the surfaces around and get a proper deformed result when an object is made up of multiple surfaces that share edges at trim curves - the surfaces can easily have control points that are not aligned with the trim edges, so if you just move surface points around the trim edges will tend to come apart in gaps.
There is a better description of this problem with some illustration (including showing how a gap gets opened by NURBS surface control point manipulation of a solid) here.
Luckily it is not all negative - this same structure that makes it more difficult to have deformations also is what makes booleans work really well with NURBS, since when pieces are trimmed the underlying surfaces do not get any more complex themselves and instead new trim curves are created. Those trim curves can also be removed later to recover the underlying surface.
Anyway I would definitely like to include these kinds of tools in the future, it is just not an easy area to work on so it may be a while.
2487.19 In reply to 2487.18
Burr's MoI Bend function.
Dont laugh Danny! :O
2487.20 In reply to 2487.19
Tricky but maybe not very easy :)
2487.21 In reply to 2487.20
I think its easier to sweep the rectangle. But if you want to work like this, one could create a "Library" of preexisting shapes to import into MoI and bend away!
2487.22
@Pilou
The problem with the projection method is that the 'pattern' you project is somehow stretched, because ... it's a projection on one axe.
A bend should deform the pattern/text in a more uniform way.
2487.23 In reply to 2487.22
@ PaQ : So waiting the bend :)
Show messages:  1-11  12-23
