Modeling problem question....how would you model this?
 1-16  17-24
2164.17 In reply to 2164.10
Hi mushroomgod - the "tangent" mode for sweep is for a special setup where you have all cross-sections being planar slices all arranged to be on parallel planes, some details on that here:
http://moi3d.com/1.0/docs/moi_command_reference7.htm#sweep
It doesn't look like your profile curves are all on parallel planes, so that option won't do anything for your case.
Right now MoI only has some limited tools to ensure smoothness - you generally need to use the Fillet or Blend tool for that, commands such as Sweep or Network do not right now have the functions inside of them to adapt the surface to maintain smoothness to an already existing one.
So generally the method is that you don't actually try to make them smooth yourself directly when your surfaces are first created - make them intentionally creased and then put a fillet in between them to make a smooth connection automatically. If you check out those steps I was using previously in this thread here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2164.2 that i the method that I was using there.
In the example that you show, you're basically trying to do the fillet's job all built into the sweep at one time - that is not going to work in MoI currently.
In the future I do want to add some more options into sweep and network to ensure smoothness with adjacent surfaces, but those are some fairly advanced surfacing techniques, it will be a while before those are added into MoI.
2164.18 In reply to 2164.16
Hi mushroomgod - here is an example with the file you posted:
Using your same side surfaces, but build a sweep that is a flat piece instead of trying to make it rounded at the corners:
Then use Fillet to produce the final rounded areas:
You may want to use the Shape: G2 Blend option in fillet to put a more flexible blend in there instead of a circular arc.
2164.19 In reply to 2164.17
Yeah I figured as much, no problem though, the shape I have now is pretty much spot on, I think the client will be happy :)
I think MOI does boolians and fillets so well the only thing its really lacking (for my style of modeling atleast) is like you say some good tools to maintain smoothness over a number of different patches/networks.
But for everything else the software is worth its weight in gold!
for example, this (cant remember if I posted this)..very simple and super quick - 90% moi
2164.20 In reply to 2164.19
Beautiful work, both geom and render.
David
2164.21 In reply to 2164.19
Hi mushroomgod - that is a fantastic guitar!
I do expect to add more functions for maintaining smoothness in the future, but there are still some kind of more "basic" areas than that which I am still working on first.
Crazy model!
2164.23 In reply to 2164.22
cheers guys, the guitar is a CD single cover for a uk band, I also did the album and a few other singles for them, MOI was used thoughout
Attached is another update of the train, looking a million times better than the subd model, much cleaner and tighter
2164.24 In reply to 2164.23
Hi mushroomgod, it is coming together nicely!
Yeah with subd sometimes the "everything totally melted" type mechanism behind it can be not quite right for things that should have more structured details in them.
The full melting effect is great for things that should have very melded features like a human face, but the more kinds of distinct cutouts and sort of "panelized" type features tends to go along with NURBS modeling more...
Show messages:  1-16  17-24
