Symetry curve creation.
All  1-8  9-13
2136.9 In reply to 2136.8
Seems "Helpers" make the same and many more ;)
2136.10 In reply to 2136.8
Hi Dave,
> i have always loved how ashlar do it and wondered
> if we could get something like this in moi?
Yup, you can have that in MoI right now! :)
To do those kinds of functions in MoI use a construction line.
Here is a quick demo using some construction lines in MoI for the kinds of alignments that you were showing. Note - if you want to get 45 degree angle snapping, go to Options / Snaps / Straight snap options / Snap angle and change that from 90 to 45.
You can get a construction line when you are in a drawing command. Instead of clicking and releasing to place a point, press down the mouse button and hold down and drag away with it still pressed. Don't release the mouse button until after you have pulled away. That will pull out a construction line that you can use for those kinds of alignments.
In fact construction lines allow for quite a lot of things that Ashlar's snapping does not - one example for mirrored snap points was shown earlier in this thread here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2136.2
Also using construction lines you can get things like the point halfway between any 2 points on the screen (instead of only along an existing edge), snap to any increments like 1/5 the distance between any 2 points, track along an elevation line in z in the 3D view, capture a length and reapply it from a new base point, and several other things.
One difference is that they do not pop up completely automatically like Ashlar's ones do - you need to do that "hold and drag" gesture to activate one. But that is actually another important benefit, because the automatic ones can just too easily pop up too many snaps and get in your way preventing free placement of points when you want to draw freeform curves instead of only lines.
Construction lines are discussed at one point in the Pod tutorial here:
http://moi3d.com/1.0/docs/tutorials.htm
And some details on them in the documentation here:
http://moi3d.com/1.0/docs/moi_command_reference10.htm#constructionlines
Please let me know if you have any difficulty getting the kinds of alignments that you want after using construction lines!
2136.11 In reply to 2136.10
no no im not complaining about the helpers in moi and i know they can do more than ashlars. it was the fact they come automatically that i miss
2136.12 In reply to 2136.11
Hi Dave - I've found that the ones that come automatically can get in the way too easily.
For instance when I try to draw a freeform curve in Ashlar pretty quickly the whole screen can get locked up in different automatic snap zones. That prevents you from being able to draw a smooth freeform curve that may require pretty subtle arrangement of the points.
I agree that the fully automatic method works well with very simple drawings that contain mostly lines and circles.
But I wanted to make a method that could do the same kinds of things, but also not cause problems when you tried to draw more freeform shapes as well.
When I go back to watch your video, you are making very much the same kind of movement as what you do in MoI to use construction lines. I mean in your video you frequently move the mouse over to hover over a point you want to activate as a snap source. In MoI you do the same amount of cursor movement, you just also add a press down and release with the mouse button.
In addition, the fully automatic way just does not cover a lot of functions, since it only radiates a line out from a single base point.
One reason why MoI is able to offer so much additional functionality with its construction lines is that its mechanism allows for specifying 2 points - a start point where you click down and an end point where you release. That incorporates a distance element into the mix, so you can do things like find the midpoint, 1/5 or whatever increments, the mirrored endpoints, etc...
The automatic method with its "single base point" lines does not have the same amount of information to work with.
Anyway, those are some of the reasons why MoI's construction lines are set up the way that they currently are, rather than that other way.
2136.13 In reply to 2136.12
yes more with moi's way but i was thinking of simple automated like ashlar and the bonus of having that extra click hold down helper thing. i agree that in larger scenes it can get in the way. anyhoo i was just thinking out loud and like i said i ain't dissing moi's helpers and i know they can allow us to do more. so i am not unhappy at all :)
Show messages: All  1-8  9-13
