Sketchup SKP export
 1-3  4-23  24-43  44-63  64-83  84-90
1978.24
Thanks for your answer. In my case, after exporting an SKP file from Rhino, I use a ruby script (delete coplanar edges) to reduse the extra geometry. So is there a possibility selecting your method (much better of course) in small models and like Rhino's in case of large models?
Regards,
1978.25 In reply to 1978.24
Hi George - actually there will be no need to worry about that, I've been able to rework the new exporter so that what was taking 10 minutes with a larger model now only takes 10 seconds. So it should be suitable for handling large models now as well.
The main limit will be that SketchUp does not really handle models of a much larger size very well itself, so if SketchUp is sluggish with the model you may have to try lowering the density that you use for curved surfaces to avoid creating too many polygons.
I think you'll be really happy with it though, you should get optimal results right away without any need for cleaning things up. Please let me know how it works for you once you get a chance to try it after I have wrapped up this next beta.
1978.26 In reply to 1978.25
Thank you very much for your answer. Can't wait to test new beta.
Keep on the great work.
George
1978.27 In reply to 1978.25
Hi Michael ...
When might we see the next beta?
cheers,
eric
1978.28 In reply to 1978.27
Hi Eric - nearly there, I think I should be able to wrap it up tomorrow.
1978.29 In reply to 1978.28
Great news!
thanks,
eric
1978.30
Great work on this one, Michael!
-Will
1978.31 In reply to 1978.20
From where can I get this plug-in for SketchUp?Sorry,I just do not find it.I am a new user of moi 3D,it is a fantastic little gadget:)
1978.32 In reply to 1978.31
Hi Alex - I'm glad that you like MoI! :)
The SKP exporter is one of the new functions for MoI version 2.0, you can download the v2 beta to test the new functions from this page: http://moi3d.com/beta.htm
Also there is a patch for the current v2 beta to fix a mirroring bug:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2177.10
You can apply that patch after installing the v2 beta to fix a bug in it.
There is also a lot of other new stuff in v2 aside from SKP export!
There are some notes on the new stuff so far here:
http://kyticka.webzdarma.cz/3d/moi/doc/V2releasenotes.html
and for the newest one here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2170.1
1978.33 In reply to 1978.20
I haven't read the whole thread yet but i want to ask a specific question that accrues to me at this point.
Is there an option to determine the resolution of how the curved faces are being split up (how many increments in the curve) when importing the skp file?
This geometry would be quite simple to do in sketchup from scratch, but I'm worried about the amount of resulting faces. In sketchup I would be able to determine how many segments the arch will be made of, e.g. 12 sides or 24 or 36, depending on the required detail.
I'm new here and I love the MoI already great software! Thanks for doing this!
1978.34 In reply to 1978.33
Hi Bruell, welcome to the forum and to MoI!
Yes - when you export to .skp format, the Meshing options dialog will be shown which has various options for controlling the density.
More details on how the meshing options work here:
http://moi3d.com/1.0/docs/moi_command_reference10.htm#meshdialog
By moving the slider or adjusting the other options you can generate either a coarse low-polygon version of your MoI object to the .skp file, or generate a higher detailed but heavier version for something like a final rendering.
MoI works on curved objects so it is kind of different than SketchUp - when you create a circular type object in MoI it is an actual circular object so you don't have to decide at creation time how many sides you want it to have, you can decide that later on when you export to a polygon-based file format.
That allows you to export many different density versions of your same base MoI object, you don't have to specify the density at creation time unlike what you are used to doing in SketchUp. The bad part about doing it at creation time is that it kind of "locks in" that density for that shape and it is not typically easy to go back later on and change it since SketchUp only knows about lines, it doesn't know that a bunch of lines actually initially came from a circle...
Yeah, it's not a complex model so doing it from scratch in almost anything is certainly not out of the question.
However, a model like this that involves cutting several pieces by profile curves will come together extremely fast in MoI, probably something like only 1 minute to completely finish that shape from scratch. Maybe I will have to make a video to really show what I am talking about here...
But don't get me wrong - SketchUp has its own different kinds of strengths and speed in different kinds of situations as well.
1978.35 In reply to 1978.33
Hi Bruell, just to give you a better idea of the speed that I was talking about, here is a realtime screen-capture video that shows how to build this shape in MoI - total modeling time is only 1 min 17 sec.
It would be interesting to know if you could build that in Sketchup in the same amount of time, do you think it is possible?
Download video (1.8MB) or play below:
1978.36 In reply to 1978.35
Hi Michael
Yes I believe that is possible in less one minute ! ;)
But a little training is necessary
and for this particular form Symmetry will be a big help!
EDITED: 4 Jan 2009 by PILOU
1978.37 In reply to 1978.36
Hi Pilou, it would be great to see the steps!
But you know, 1 minute and 17 seconds goes by really quickly, are you sure you can do it in that amount of time? :)
I'm not familiar with a symmetry tool in SketchUp - is that a plugin?
1978.38 In reply to 1978.37
Yes there is the mirror plug!
Rest is only dexterity ;)
Take me 5 minutes i draw you the concept ;)
Here the concept without special plug except mirror!
Speed will be made by Selection (spacebar) Push selection by "P"
The "X Push" is the normal push without special plugin : here it's very easy because you have not a lot of rectangles
so made in a three seconds!
Mirror plug (Right click on a selection) http://www.crai.archi.fr/RubyLibraryDepot/Ruby/EM/Mirror_31.rb
Ps the normal symmetry of a selection is : select anything
take the "Scale Tool"
Take a "cube green handle" make "any move" (of any distance) with it : release it
but now Enter "-1" = you have a symmetry ;)
1978.40 In reply to 1978.39
Hi Pilou, your solution looks good!
I'm not that used to Push/Pull in SketchUp so it doesn't really occur to me to use it like a boolean to cut something all the way through, but it does work fine for that.
Only 2 problems - #1 you're using a plugin instead of the "stock" SketchUp! (the solution in MoI is only using all standard built-in tools), and #2 - you appear to have extra edges in your result running down the middle of the model, I guess to get a fully clean result those would also need to be deleted as an extra step?
Also how long does it take?
Here is a new record from me, with some faster mouse clicking I get 59 seconds:
1978.41 In reply to 1978.40
No the "Edge line" on the top is like "lines seams generator" in nurbs ;)
It's only Edge Style drawing!
For the rapidity I believe that I can made all this forms in less than 30 seconds ;)
But only because it's a very simple symmetric form !
If you don't want use the extra plug mirror : you must make a Copy Move + the Scale "-1" (shown and explained above)
so maybe 5 seconds more !
But use plugs is a normal way in sketchup ;)
1978.42 In reply to 1978.41
Hi Pilou, I'm trying your steps in SketchUp, but as far as I can tell you can only push/pull one single outline at a time, is that correct?
I mean you show one step in your instructions, but is that actually 5 different push/pulls, one to cut each rectangle? Or am I missing a way to do multiple simultaneous push/pull ?
re: 30 seconds - I await your video to show it! That much time goes by very fast, so you may be surprised...
Your steps definitely look good though (except not using stock SketchUp!), but also what if the number of holes grows? I think it could be quite tedious to form each hole by an individual push/pull action.
I mean something like this for instance in MoI can be booleaned by selecting all the cutting objects in one boolean operation:
So for example that is 21 holes cut with one boolean in MoI.
1978.43 In reply to 1978.42
Yes without extra plug you must make only one surface "Push Pull" in the same time!
But........
There is the genial "Joint Push Pull" (free) by Freddo 6 ( a french guy ;) who made that you show in one pass!
http://www.crai.archi.fr/RubyLibraryDepot/Ruby/JointPushPull.zip
For the video I am rusted (no computer for 2 weeks) but trust me I can made that in a few days ;)
Ps A True Boolean plug is released by Whaat! (not free 10 $ ) http://www.smustard.com/script/BoolTools
Show messages:  1-3  4-23  24-43  44-63  64-83  84-90
