Can this be modelled in Moi?
 1-15  16-35  36-48
1952.16
Thanks for the helps guys its really appreciated.
What I don't understand though is how you created those curves Manz?
Here:
And Pilou, how did you do you 2D Sweep!?
EDITED: 10 Sep 2008 by GIZMO1990
1952.17 In reply to 1952.16
Just select the Profil (uper round top curve)
Call Sweep function
Click Rail 1 (one curve)
Click Rail 2 (second curve)
Done or Right Click
That all ;)
You can train with my previous send 3dm file (post 1952.15 )
Select the right object's surface
Delete the surface and you can make that I wrote above ;)
1952.18 In reply to 1952.17
Ok I see.
One extra thing I'd like you to explain. Presumably you used the model Manz created. If so how did you redivide up the curves of his original model into your new one with only 3 curves??
1952.19 In reply to 1952.18
Just select curves that you want and call function "Join"
If you want make some cuts in a curve just draw a line (or a curve) from the spot wished and call function "Trim"
EDITED: 10 Sep 2008 by PILOU
1952.20 In reply to 1952.10
Hi gizmo - there's also some extra information on how to arrange the curves for Network here: http://moi3d.com/forum/index.php?webtag=MOI&msg=1905.1
For Network the curves need to be arranged in a particular way that can be unwrapped to a 2D grid pattern. If your curves are not arranged in that way then it will still get forced to be like that and you can get some strange results like your first one there.
1952.21 In reply to 1952.10
Hi gizmo,
> Ok say I didn't want to create the main shape from a sphere or I
> needed it to be more specific shape wise?
It seems like you're still focusing on things a lot from a polygon modeling perspective? I mean here you're focused very much on the final edges and drawing those first.
It is possible to do that like Manz shows above, but really it can be a lot easier if you build a bigger shape that has the surface that you want, and then trim it back.
So if you don't want a perfect sphere as your main shape, draw a different profile and use Revolve or Rail revolve to create a different surface shape, then you can trim that using the same steps as was done with the sphere originally.
For example, if you take these 2 curves, and select the half one as the profile:
Then you can run Construct / Revolve / Rail revolve, and pick the longer one as the rail curve, and then pick the revolve axis between the 2 ends of the open curve, and you will make this kind of "customized sphere":
Also after you have completed the rail revolve, you can turn on control points for the curves and adjust them to update the revolve.
This can be an easier way to create a more customized starting surface because there are fewer curves involved to define it, and it will avoid some of the problems of trying to create a surface to a more complex boundary directly, which is possible but tends to be hard to control where points pinch together.
It takes a bit of getting used to if you are used to polygons, but with NURBS it can often be a good idea to build things larger than you need at first with more simple curve layouts, then trim or boolean them to produce your final result, rather than trying to build to the final outline directly.
1952.22 In reply to 1952.16
When you have 2 standalone curves (as you have colored green) you can simply make a Construct~blend between the 2 curves (use G2 to keep curvature)
1952.23
Many many thanks for all the help guys. I feel like a whole new world is opening up for me.
A quick question for anyone else still reading the thread. Can you only Boolean closed objects? I tried to union boolean the outer shell I created with the sweeped circle and all that was left behind was the sweeped circle? Should I have closed the main shell for it to work?
Right hold up I'm experiencing problems again. I've got the shell exactly how I want but how do I close it? I thought I'd simply create another curve cage but make its thickness a little smaller than the original. Ho there's numerous problems with this.
1) Copying and pasting the cage and moving it to the side to alter. How do I then get it back to exactly the same position? Object snape doesn't seem to work?
2)Because I can't get it back to the original position exactly it's out of place. When I do a Join command on the 2 shell pieces nothing happens? I'm still left with 2 pieces?
Here's an illustration of what I mean. How do I get these 2 componant to be snapped together exactly.
EDITED: 11 Sep 2008 by GIZMO1990
Size: 21.9 KB, Downloaded: 14 times, Dimensions: 396x366px
Size: 26.4 KB, Downloaded: 13 times, Dimensions: 457x329px
1952.24 In reply to 1952.23
Read the help file:- http://moi3d.com/1.0/docs/moi_command_reference7.htm#Construct_Boolean
1952.25
Thanks Manz.
Anyone know how to snap the 2 shells exactly?? And then Join the two shells together to form one part which I can then perform a union Boolean with?
I want to go from this
to this
1952.26 In reply to 1952.23
Hi gizmo,
Pick all the original wireframe and drag it from the end of that highlighted curve indicated by the arrow and there should be a corresponding point on your model to snap to as shown.
1952.27 In reply to 1952.26
Hi danny thanks for the reply. Right that seems to work in a round about kind of way. But then when I join the 2 shells together there are faults with it?
I've included 2 files. One with the 2 shells which I'd be interested in knowing how you'd snap together as well because both are shells. Rather than the shell you aligned with the curve 'cage'.
The other is the shell created using the technic you say Danny but there are faults with it when I joined them. That means that when I come to choose say fillet it for instance it doesn't work?
1952.28 In reply to 1952.27
The union or join is probably being messed up with the fact that the 2 surfaces are "Barley touching" along the edges.
A solution would be to take say the bottom piece and make it "Bigger" so the edges stick through the top surfaces edges, then your Booleans should work.
[EDIT]Bad solution.[EDIT]
EDITED: 11 Sep 2008 by BURRMAN
1952.29 In reply to 1952.23
Hi gizmo,
No, you can boolean open objects as well, however booleans are mostly oriented towards figuring out which pieces to keep and which to discard according to where they are located inside of a volume.
If the piece you want to cut is not a volume, it can be somewhat unpredictable which pieces will be kept and discarded.
In cases like that, switch to use the Edit/Trim command instead - it allows you to cut objects with one another similar to booleans, but you manually control which pieces you want to discard by clicking on them.
So in the case that you are describing use the Trim command instead.
This would likely be easier with the method that I described earlier about building a larger surface first and them trimming it back.
When you build a surface like you have there with the corners of the 4-sided surface sheet totally smooth to one another, that will create a degenerate surface normal in that area and prevent some commands such as shelling or probably filleting from working in that spot.
That's another reason why it can be better to build a larger more simple structured surface first and then trim it, rather than trying to build a surface directly to your final outline which is more of what you would do if you were building with polygons - remember you are not building with polygons here, with NURBS it is generally better to use trimming and cutting type operations to make a final outline if that final outline is different than a 4-sided sheet.
The usual method is to find a key point like an endpoint and then grab the object close to that key point to snap on to it and drag it over to the matching point on the other object, Danny showed this above but also just to be clear here is a screencap:
1952.30 In reply to 1952.27
Hi gizmo,
re: shell with fault - if you zoom in you can see that the pieces did not get really aligned properly with each other:
The pieces could join because some parts of them were close enough, but other parts were not close enough so did not get joined into a single shared edge.
You'll need to get a better alignment than that to get a clean join.
But after that I still would not be surprised if you could not fillet it, because you've got those degenerate edges in the surface patch - that's where your 4-edged surface has a tangent edges on its surface corner instead of a distinct corner, that causes problems with offset operations and part of filleting involves an offset calculation.
Again if you would use the technique described earlier on building a larger surface then trimming it back you are more likely to avoid many of the issues you are running across, you are attempting to do things in a more difficult and low level way right off the bat and that is increasing the difficulty level for you by quite a bit.
1952.31
Hi gizmo,
Michael wrote: you are attempting to do things in a more difficult and low level way right off the bat and that is increasing the difficulty level for you by quite a bit.
This is so true, your head will explode ;) trying to do surfacing type stuff like that without exploring and seeing what MoI can and can't do or having a Cad/nurbs background.
But don't get too discouraged or frustrated, the more you find out about MoI and techniques shown on the forum the more easier it will become :)
I've attached your file, after having a play with it, and as Michael mentions there is a bit of low level work to be done before you can use the Boolean and filleting tools successfully so it is possible.
One hint is that if you look at the model you will notice it's in 4 pieces joined together, so I just worked on a 1/4 of it, got that right then mirrored and joined them together to make a solid then the holes and fillets were easy after that.
EDITED: 26 Jan 2010 by DANTAS
1952.32 In reply to 1952.20
Don't know if this is of interest/value.
My starting point was a sphere with thickness.
Does the pdf in the zip explain the MoI moves well enough?
I have enclosed the .car file for those who could use it.
I have fun!
Brian
EDITED: 31 Dec 2008 by BWTR
1952.33
Thanks again everyone for your input. The willingness of everyone here to help me out and explain things is greatly appreciated.
It is really frustrating getting my head around Nurbs concepts but I really want to crack it after several failed attempts over the years. Moi's user friendliness is proving to be my saviour in this aspect.
Anyway back to the case in point. I understand totally what people are saying but what I can't get my head around is how would I be able to create the shell (exactly how I want it) without doing it the way I have? Starting from a sphere I can't see how I would be able to precisely replicate the shell dimensions I want? Perhaps someone could try and do this and prove me wrong!? Use mine as a template but create it entirely differently?
As for how my model is currently. Danny, how did you achieve the result you had!? That's 'almost' exactly what I want! I'd just like the thickness of the shell to be less. As you said I've broken mine into a smaller part but how then am I to create the underside of it like you've done?
Thanks again in advance!
1952.34 In reply to 1952.33
Hi gizmo,
What version of MoI are you using, demo or V2 beta ?
1952.35 In reply to 1952.34
The demo. V2 is locked off to current owners isn't it?
Show messages:  1-15  16-35  36-48
