wavefront-export problems
 1-11  12-22
1620.12 In reply to 1620.10
sorry for posting here bit by bit, but i have to correct myself. The last to shots from the lefthand side and from the righthandside are both n-gons.
From one side the ngons are working correct. From the other side not.
Sorry, i`m really no expert here.
The other ways you`ve mentioned above don`t work for me. best thing is just to delete these points.
But if it is some Maxon-related problem i would like to tell them.
Greetings
Dirk
1620.13 In reply to 1620.10
Hi Dirk,
> It seems Moi or c4d uses a whole triangle for the edge of the fillet.
MoI is making an n-gon there, there are no triangles involved at MoI's export time (unless you set that option of course) - it just happens to be an n-gon that has several points that are near to being colinear with one another as they follow some curvature.
C4D will take that n-gon and then break it into triangles for display and rendering purposes, and it's that triangulation process that is probably not going quite as well as you would want.
The way that would be good to triangulate it would be like this:
That gives triangles that kind of more gradually spread across the n-gon, instead of the previous case that I showed where you get 2 big triangles and one degenerate one. But unfortunately it looks like you are getting that bad case in C4D's n-gon triangulation.
1620.14 In reply to 1620.12
your were to fast with your reply ;)
If there is no workaround, i can live with that.
I would like to tell maxon about this problem, but i`m not sure if i can explain this issue well enough to them to make them understand.
Well, i will try it and direct them to this thread here.
Thanks for your effort Michael
Dirk
1620.15 In reply to 1620.14
Hi Dirk, I took a look at your OBJ file, and it does look to be the problem that I was describing - the triangulation that C4D created is not so good and is following the example I showed above where it pulled out large triangles during the initial stages of the triangulation process and left a degenerate one along the side there.
Actually on the one side where it is showing black, I think that triangle actually got created in the wrong orientation, facing backwards - that's why it is black.
One workaround is to export from MoI as quads & triangles - that will end up using MoI's triangulator which won't do that.
I think it is also possible to manually edit the triangulation of an n-gon in C4D if you want to change how the n-gon is being diced up, there is something in C4D under Tools / N-gon Triangulation, I'm not quite sure how it works though.
One other thing to mention - it is pretty hard to see the triangle problem in an actual rendering, it is much more pronounced when you're zoomed in and looking with the real-time view.
I may be able to try and reduce the creation of this kind of shape in the future, but it is actually a proper n-gon, I mean it is not technically messed up or anything like that. It would be good if C4D would create a better triangulation for it.
It may be pretty difficult to describe this to Maxon, but I hope that the step-by-step triangulation illustration that I showed above may help...
Also, one other note - there is a setting you can tweak in the moi.ini file to change how MoI will produce a triangulation for things like that, by default it will do a kind of radial triangulation when possible, adding an extra point in the center of n-gons like that. It is possible to turn off that style and instead only use points along the outside of the n-gons, let me know if you want more info on that.
1620.16 In reply to 1620.14
Hi Dirk, just one other comment if you want to submit this to Maxon as a bug report, I would suggest deleting all the other polygons except for just one single one that has the black thing on it (but before yanking the points around), and then sending a file in with just that one n-gon in it as an example of the triangulation problem.
It helps a lot with bug reports to have the most simple data set possible that shows the problem.
It may not be a very easy thing to fix though, it can take a pretty big re-working of the triangulation mechanism to make one that does not back itself into a corner like this.
1620.17
If you're having problems getting OBJs into C4D, I recommend you try the RipTide plugin:
http://skinprops.com/riptide.php
http://skinprops.com/fr_rtdocs.htm
C4D is known to have quirks and limitations to its OBJ importer hence the reason why RipTide was created...
-Will
1620.18 In reply to 1620.17
Thanks Will,
i`ve just tried Riptide, but unfortunately it doesn`t work in this case.
By the way, is it possible to direct someone directly to this thread?
The url in my browser just says: http://moi3d.com/forum/index.php?webtag=MOI
Greetings Dirk
1620.19 In reply to 1620.18
vinced, middle mouse button new tab.
http://moi3d.com/forum/messages.php?webtag=MOI&msg=1620.1
1620.20 In reply to 1620.18
Usually all the way at the bottom of the page there's an "All" link or "1-nn" link, those will also take you to the first post of the thread you're in. ;-)
-Will
1620.21 In reply to 1620.18
Hi Dirk, also if you look in the upper-right corner of a message there is a link up there, like this one should say something like "1620.21 In reply to 1620.18"
Those little links are "permalinks" to an individual message, you can right-click on it and copy that address to the clipboard to give to someone else. If you want to give a link to the whole thread, go to the first message and grab it's permalink.
1620.22 In reply to 1620.18
"i`ve just tried Riptide, but unfortunately it doesn`t work in this case."
Sorry to hear it didn't work out for ya - Keith is presently tuning up his plugin and he's taking input from this thread here:
http://forums.cgsociety.org/showthread.php?f=47&t=624337
You may want to pop in and mention the problems you had or if you have some suggestions etc.
-Will
Show messages:  1-11  12-22
