Shelling
All  1-5  6-16
1573.6 In reply to 1573.5
Hi Paul,
When shelling a solid box, you need to select a face that is to be shelled.
Example:
Select shell command, then select object:-
you then select the face to shell (left click the face in any view)
Then select "done" (or right click) that will bring up the option box where you can select wall thickness and direction.
You can of course, select the face before the shell command if you prefer.
Hope that helps,
- Steve
EDITED: 3 Aug 2009 by MANZ
1573.7 In reply to 1573.6
Hi Steve,
Ahhhhh...thats how !!
Thank You
--Paul
Select 2 faces and look the result ;)
1573.9 In reply to 1573.8
Thanks Pilou,
Selecting 2 faces opens up the possibilities!
I need to ask a few questions and post images...is it possible to install the 30day demo as well as leaving the alternate version on system ?
TIA
--Paul
1573.10 In reply to 1573.9
Hi Paul,
Also check out here: http://moi3d.com/1.0/docs/moi_command_reference7.htm#shell
for some other information and examples on shelling.
Shelling is a pretty complex operation though, there are a lot of possible things that can prevent it from working, such as asking for a thickness that causes pieces to run into or overlap each other.
If you need to do a whole lot of more advanced shelling, you'll probably need to use a different modeler like SolidWorks or Pro/E that has a more developed shelling system.
But for simple things MoI's shelling should be useful.
> version on system ?
Yup, they can both be installed at the same time. By default I think they will want to go into the same folder named "MoI 1.0 trial", so when you install the second one just give it a slightly different folder name when the installation folder comes up.
1573.11 In reply to 1573.10
Appreciate the quick response by you & everyone on this forum !!
I can in fact shell a lot further with our other parametric modeler which is a shame but there is another
way my end result can be made. Can I import an STL model into MoI and then create a drape surface or
reverse engineer (like rhino reverse) some nurbs surfaces from the mesh ??
You have born a great piece of software, all credit to you.
--Paul
1573.12 In reply to 1573.11
Hi Paul,
No, sorry - MoI doesn't import polygon data.
The closest thing to that right now would be to convert from STL into OBJ format, then use the OBJ to 3dm Wireframe converter here to convert the polygon wireframe into line segments in a .3dm file which can then be loaded into MoI.
MoI is much more intended to be a tool that you use to create objects from scratch, and not as a reverse engineering tool.
Probably at some point in the future when MoI supports plug-ins (maybe for version 3.0?) someone might make a reverse engineering plug-in or something. But until then it just is not the right tool for that kind of a job.
1573.13 In reply to 1573.10
Speaking of Pro-E, I use that at work, and I just installed the Wildfire 4.0 Tryout Edition. It know can directly read in .3dm model files.
Just thought I would let you know.
Michael Tuttle a.k.a. mictu http://www.coroflot.com/fish317537
1573.14 In reply to 1573.13
> model files.
That's good news!
Stuff like this is the reason why I wanted to use .3dm as MoI's main file format instead of creating some new kind of file format.
1573.15 In reply to 1573.12
Thanks Michael.
I'm enjoying playin at the moment and watching tuts......
Rgds,
--Paul
1573.16 In reply to 1573.13
It should also work with Pro/ENGINEER Wildfire 3.0 when plug-in installed - http://www.ptc.com/view?im_dbkey=69075
Show messages: All  1-5  6-16
