Fillet problem
All  1-6  7-19
1515.7 In reply to 1515.6
Thanks JBS.
That way of doing it sugests an idea for getting some interesting carving effects--will see what I can come up with today.(Lateral thinking involved!)
1515.8
is there a trick at step 6, I can't blend the two pieces :(
1515.9 In reply to 1515.8
Hi rickky - can you please upload a .3dm file attachment with your model that you can't blend?
It really helps to have a .3dm model file to go along with your question, it is otherwise difficult to guess at what the problem might be.
1515.10 In reply to 1515.8
Hi Rickky. When you positioned the circle profile, did you align it with the vertical edge of the cylinder wall? This is important, otherwise the boolean would leave an extra edge around the top face. And MoI's blend tool does not "chain" along tangent edges...
jonah
1515.11
Here there's a file with my process before and after blending
Don't work. I miss probably something
1515.12 In reply to 1515.11
Hi rickky - right now in MoI blending can only happen between 2 edges (one from each surface).
Your circular disk has one edge around the outside, but the cylinder part is broken up into 2 edges.
In order to blend this particular shape you will need to split the disk edge into 2 pieces so that you can match them up in pairs with the cylinder one.
To split the disk edge, select that edge, then run Edit/Trim, click "Add Trim points", and click 2 points on it to cut it into 2 sections that correspond to the edges on the cylinder part.
After that, you can then select pairs of edges between the 2 surfaces and create a blend, then repeat with another pair and create a second blend.
Like Jonah was mentioning, if you position the circle for your sweep at the "seam edge" of your cylinder, then that would produce only one single edge on the cylinder piece and be easier to blend since there would be only one edge on each piece.
Please let me know if this doesn't make sense and I can give you some step-by-step instructions.
1515.13 In reply to 1515.11
Hi Rickky,
If you check the model you will see the outer edge is broken:-
That is a problem due to how the seam from the boolean is passed to the object.
To workaround, before the sweep, construct the circle on the seam of the cylinder.
- Steve
Edit,
sorry, cross post with Michael. You can delete this post.
EDITED: 3 Aug 2009 by MANZ
1515.14 In reply to 1515.13
Yours is better with the illustrations!
1515.15
At first, thanks all for your (patient) support
But.... Ahhhhhhhhh !!!!!!!!
I'm going to be crazy or Nurbs workflow is particular
I don't undersatnd all the process
1515.16 In reply to 1515.15
you will understand with more practice, don't worry! Just keep in mind these small details as you model...
jonah
1515.17 In reply to 1515.15
Hi rickky,
Well, it's quite a bit different than polygons.
I do have some description here that describes some of the differences for how a NURBS object is set up.
You're kind of running into a couple of issues in this particular circumstance that are kind of pushing it more towards a somewhat more advanced type of "trim and blend" type modeling, rather than solid style modeling which tends to be more straightforward.
If you wanted to do the more standard style constant-radius fillet then you wouldn't have to mess with any of this and could just use the Fillet tool and be done.
In the future it should be possible to have options for constant-distance fillets and also an option for using more than just 2 edges for a blend, either of which would make this particular thing have fewer steps in it.
1515.18
Ahhh yessss
My first step in Nurbs world :)
Size: 124.8 KB, Downloaded: 34 times, Dimensions: 760x803px
1515.19 In reply to 1515.18
looking good, rickky...
Show messages: All  1-6  7-19
