Feature or workflow?
All  1-6  7-8
1343.7 In reply to 1343.6
#1 where is this "Relocate cline"
#2 i think the axis locking feature would be a great addition to moi, custom planes or not it would be a nice quick modeling aid without going through the create custom plane senario each time.
thanks for the responses,
would the axis locking be posible with a quick script?
did you think of any tips for me when i get to the corner junction of my model?
1343.8 In reply to 1343.7
Hi xrok1,
It's covered in the help file under construction lines:
http://moi3d.com/1.0/docs/moi_command_reference10.htm#constructionlines
When you create a construction line, a little tag will appear above your mouse - click and hold down on it (keep the mouse button pressed down) for a second and that menu will pop up with a bunch of additional options to control the construction line.
You should be able to get a lot of axis-locking type of functionality from the construction lines - for example the steps I showed above gives you the equivalent of a z lock.
The nice thing about the construction line method is that it isn't actually limited to just world axis directions - you can drag out a construction line between any 2 points to use any direction that you want. But at the same time straight snap will help you to get axis directions if you want.
That's definitely going to be tough - it is hard to branch when doing a contour slice type method.
You'll probably have to build some things as separate pieces and then cut some holes and add some blends to connect pieces together.
Show messages: All  1-6  7-8
