Shortcut Key for Grid on Top?
All  1-7  8-14
1311.8 In reply to 1311.6
Hi Brian, there isn't currently any way to display the grid over top of everything instead of underneath it.
It shouldn't be hard for me to add that when I start working on new features again. It will be a few weeks or maybe a month before I'll be ready to do that.
In the meantime I have added this to the wiki wishlist: http://moi3d.com/wiki/Wishlist so that I can keep track of it.
Waiting that you can make a new objet as a "grid" that you put anywhere you want !
1311.10 In reply to 1311.9
Thanks Malc and Michael.
Yes Michael, that would be good. The current alternative, using the Hide option, seems to be a bit "fragile' in its working--does things not expected?
But, just to be able to have that overlay to allow precise location of a work in relation to an object, just seems a sweet way to work.
Brian
1311.11 In reply to 1311.10
To do this, you could consider using a construction lines instead.
See http://moi3d.com/1.0/docs/moi_command_reference10.htm#constructionlines
For example, there is an explanation for putting a cylinder on top of a box precisely".
Petr
1311.12 In reply to 1311.11
Thank you Petr, just not as simple/easy as I grid overlay maybe though.
1311.13 In reply to 1311.12
I see elswhere talk of wire or mesh view options.
I wonder if there could be an object transparency slider instead?
Being able to see through the objects grey/yellow if required may solve a lot of problems perhaps?
1311.14 In reply to 1311.13
Hi Brian, one major thing that the wireframe mode would do would be to speed up the display by a lot since it avoids the creation of display meshes.
Transparency wouldn't have that same "speed increase" effect, so it's not really something that would be a replacement for wireframe mode, but it could certainly be useful for other purposes.
I have added it to the wiki wishlist: http://moi3d.com/wiki/Wishlist
Show messages: All  1-7  8-14
