Shortcut Key for Grid on Top?
All  1-9  10-14
1311.10 In reply to 1311.9
Thanks Malc and Michael.
Yes Michael, that would be good. The current alternative, using the Hide option, seems to be a bit "fragile' in its working--does things not expected?
But, just to be able to have that overlay to allow precise location of a work in relation to an object, just seems a sweet way to work.
Brian
1311.11 In reply to 1311.10
To do this, you could consider using a construction lines instead.
See http://moi3d.com/1.0/docs/moi_command_reference10.htm#constructionlines
For example, there is an explanation for putting a cylinder on top of a box precisely".
Petr
1311.12 In reply to 1311.11
Thank you Petr, just not as simple/easy as I grid overlay maybe though.
1311.13 In reply to 1311.12
I see elswhere talk of wire or mesh view options.
I wonder if there could be an object transparency slider instead?
Being able to see through the objects grey/yellow if required may solve a lot of problems perhaps?
1311.14 In reply to 1311.13
Hi Brian, one major thing that the wireframe mode would do would be to speed up the display by a lot since it avoids the creation of display meshes.
Transparency wouldn't have that same "speed increase" effect, so it's not really something that would be a replacement for wireframe mode, but it could certainly be useful for other purposes.
I have added it to the wiki wishlist: http://moi3d.com/wiki/Wishlist
Show messages: All  1-9  10-14
