Custom distance script will not work
All  1  2-6
1231.2 In reply to 1231.1
Hi Rudy,
>>Somehow, when I open MOI, press ALT+D, nothing will happen. The custom distance will not come up.
Make sure, the shortcut Alt+D exists! Open options dialog window; in the Shortcut keys section there should be:
   Alt+D     CustomDistance
or you can set up the different shortcut if you want.
When you unzip a custom command into the command folder, the shortcut isn't created automatically for this new command. You must set it up manually first.
Petr
1231.3 In reply to 1231.2
Dear Petr,
I remember something like that, yes...it is in notepad. I remeber the section too.
But I do I go in the options dialog window. I do not remeber how to get there.
Thank you man,
Rudy
1231.4 In reply to 1231.3
Dear Petr,
But how do I go in the options dialog window?. I do not remeber how to get there.
Rudy
1231.5 In reply to 1231.3
Just click the "Options" button next to the "Help" one, then Shortcut keys tab.
Options
See http://moi3d.com/1.0/docs/moi_command_reference10.htm#shortcutkeys how to define a shortcuts.
1231.6 In reply to 1231.5
Got it.
Thank you T.
Show messages: All  1  2-6
