3D View reset Gizmo/Fly cam
All  1-2  3-6
11994.3 In reply to 11994.1
Or if you want to reset the 3D view's pivot point for orbiting the camera you can do that by selecting your surface and then click the "Reset" button on the view:
You can also set the 3D view rotation pivot to a specific point using the Zoom Area button on that same toolbar.
11994.4 In reply to 11994.3
if the object or gizmo is named i think using command line and/or scene browser with reset view is very fast...
it could be 10km away i would search for "gizmo" or "object name" (direct in the command line, by pressing tab and typing)
then type "reset" if you have a script to do that, or use a shortcut key.
you can use options>shortcut key:
moi.view.resetAll();
i personally prefer to use command line searches or actions at moment so i created a simple text file in notepad saved it with filename reset.js to commands folder in windows: User\AppData\Roaming\Moi\Commands
EDITED: 16 May by LIGHTWAVE
11994.5 In reply to 11994.3
Thank you!
That works!... I missed it in usage. (Well, I am partly excused for it because I use MoI only as a bridge importer/exporter between Rhino and LightWave.)
Ufff, yes... after mastering scene control in Unity (which is perfectly done!), it becomes very difficult.
Perhaps you could add a middle mouse click command (currently missing in the options) so we can assign any command to it.
11994.6 In reply to 11994.5
hi yanus, looks like middle mouse button is permaset to pan
"Middle click for Pan, and the scroll wheel for zooming"
https://moi3d.com/wiki/Shortcut_Keys
I searched through the moi ini "mouse" but didnt see a middle click setting
Maybe there is an ini setting or option could be introduced..
Not tested but maybe this might help:
X-Mouse Button Control (XMBC) is a free tool for Windows that allows
you to re-configure and remap mouse buttons to expand the capabilities of your mouse.
https://www.highrez.co.uk/downloads/xmousebuttoncontrol.htm
im sure theres other tools. Also nearly all current Logitech mice
with a physical middle-click (usually activated by pressing down on the scroll wheel)
are programmable. However, button customization depends on the model's software family.
cheers
stefano
EDITED: 18 May by LIGHTWAVE
Show messages: All  1-2  3-6
