Boolean
All  1-3  4-10
11726.4 In reply to 11726.2
Thank you Grendel
11726.5 In reply to 11726.3
Thank you PILOU,
but I prefer that you deform it
11726.6 In reply to 11726.5
It's deformed (an arc surface against a flat line surface! ;)
And of course you can give any form at the target ribbon surface!
My Moi French Site
11726.7 In reply to 11726.3
WOW...this is good to know. I never did understand the deform tool. We need more postings like this on using some of the more advanced tools.
I've always had hit or miss with the network tool. Some times it works other times after an hour or so of fiddling I simply give up.
11726.8 In reply to 11726.7
http://moi3d.com/4.0/docs/moi_command_reference7.htm#network
Normally result is quasi instantaneous ...if not curves are not well positionned between them ! ;)
Else Flow is terrific for project deform any volume on any other one! :)
EDITED: 11 May 2025 by PILOU
A cool use of the Network function... as direct modeling! :)
Of course you can use it on a more elaborated "Volume"! (with the other modes following positions of curves! )
Here just a simple surface! :)
EDITED: 12 May 2025 by PILOU
11726.10
To me, the NETWORK and DEFORM tools are what truly make Moi3D stand out from the crowd.
This kind of organic shape is actually pretty easy to model in Moi3D—perfect for jewelry design!
EDITED: 18 May 2025 by ELANG
Size: 350.6 KB, Downloaded: 158 times, Dimensions: 1527x985px
Show messages: All  1-3  4-10
