Writing on a oildrop
All  1-6  7-15
As brian said, you don't have to flow line to line but surface to surface.
Now you have to do choice how you do the target surface :
- iso curves and cutting
- boolean cutting
- another method you choose ?
11568.8
Thank you all, but could you explain it a little more precise
First, Flow use source and target to adapt objects from source to target.
Those Source and target can be both curves or both surfaces.
Documentation for Flow is here
http://moi3d.com/4.0/docs/moi_command_reference8.htm#flow
Documentation for Iso
http://moi3d.com/4.0/docs/moi_command_reference7.htm#isocurve
You have to turn your drop to avoid problems with cutting an edge next.
Use ISO curve -----> Construct/Curve/ISO
When you have your curves, you can select drop + Curves and Trim it -----> Edit/Trim
Now you have a surface which could be a target surface.
Construct a rectangle on your Text which could be a source surface.
You can now use the Flow function -----> Transform/DEform/Flow
If you want delete the cutting of your drop, select text on drop Copy it with Ctrl/C
press Undo many time to return on the situation you want then Paste iwith Ctrl/V
EDITED: 22 Oct 2024 by PHIRO
Size of flowed text could be adjusted by:
Change 2d rectangle size.
Or change text size,
Or ...
Ratio of height to width may also change, unless...
As Brian wrote it, I explain the theory to be easy understood.
Next you can tune your process as Brian wrote it if you want a better result by modifying your source or/and target surfaces.
11568.12
Thank you all. I will try it tomorrow.
11568.13
My preminilary result
11568.14 In reply to 11568.13
Very good result!
Can alignment of text be slightly changed by moving and/or slightly rotating base surface?
EDITED: 25 Oct 2024 by BEMFARMER
11568.15 In reply to 11568.14
I didn“t try it.
Show messages: All  1-6  7-15
