Framing camera rotation around selected object + centering view
All  1  2-6
11112.2 In reply to 11112.1
The next script will help you.
MoveTargetToObjectsV2 – Rhino-like command; moves a viewport target's position to the center of the bounding box of selected objects.
Alt+Q script:var objs = moi.geometryDatabase.getSelectedObjects(); if ( objs.length > 0 ) { moi.ui.mainWindow.viewpanel.getViewport('3D').targetPt = objs.getBoundingBox().center; }
11112.3 In reply to 11112.2
Or also the one from here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5392.4
11112.4
Hello both ! Well, that's perfect (and so much more relaxing than having to unzoom each time !). Thanks :)
I see that the code for the two versions is very similar. Is one more robust than the other ?
Also, I think this would be great to have by default, as a button. I feel like people might very much enjoy this even though it may not feel like an obvious necessity at first. As a matter of fact I've used MOI for years now with feeling like it was a dealbreaker not to have this ; but because of the specific thing I was working on yesterday (involving some tricky inspection of parts and dimensions) it really became obvious how disorienting the frame+zoom was.
11112.5 In reply to 11112.4
Hi pior,
One version operates only on the 3D viewport, the other one operates on the active view including if it's an ortho view.
11112.6 In reply to 11112.5
Excellent, thanks makes sense. Thanks !
Show messages: All  1  2-6
