Select all faces inside an edge loop?
All  1  2-11
11003.2 In reply to 11003.1
Here are a couple of scripts that I've gathered from the community here...
script: /* SELECT LOOP */ moi.geometryDatabase.selectLoop();
This one requires you to select one or more edges and then run it (sometimes 2 selected edges are required if it's nested among joined surfaces). It'll select all the bordering edges of the adjacent surface(s).
script: /* SELECT ALL NAKED EDGES */ var gd = moi.geometryDatabase; gd.deselectAll(); var breps = gd.getObjects().getBreps(); for ( var i = 0; i < breps.length; ++i ) breps.item(i).getNakedEdges().setProperty( 'selected', true );
This one doesn't require anything to be selected prior to running. It will select all the "border edges" of all joined and unjoined surfaces. It's a great way to see where a shape has problems becoming a watertight solid, as well.
...maybe these are what you are looking for.
EDIT: Sorry, I should mention that these scripts need to be added to the "shortcut keys" in the "options" popup to be used effectively.
EDITED: 3 Mar 2023 by ECHOLOCATING
11003.3 In reply to 11003.1
Hi Chris,
> another question: is there a way to select the faces inside an edge loop? The edge loop
> is the boundary for the faces selection so to say.
Could you please show an example?
11003.4
thanks I have those 2 scripts in use already.
Fill slection is a workflow from polygon tools. For example here:
https://www.youtube.com/watch?v=q1iARRbYCvg
https://www.youtube.com/watch?v=WRGN1BSqnfI
The edge selection determines the faces selection border. That is a very effective workflow since it makes selctions on complex objects very easy
11003.5 In reply to 11003.4
Hi Chris, try the attached SelectFill plugin.
Instructions for installing a plugin here.
You'll need to set up an edge selection first, like this:
Then when you run it, you need to pick a face:
And then only faces inside the same zone bounded by the edges should get selected:
Hope that was what you were looking for.
11003.6 In reply to 11003.5
that is absoutely awesome! Thank you very much. You just accelerated my workflow tremendously!
11003.8 In reply to 11003.7
Hi Pilou, it doesn't work on your case there because those are independent surfaces not joined to each other.
If you select those surfaces and use Edit > Join to glue them together into a connected object, then it should work.
11003.9 In reply to 11003.8
Excellent!
EDITED: 5 Mar 2023 by PILOU
You can click any face inside the loop!
here the last (or the first depending of your point of view! :)
11003.11 In reply to 11003.10
Yes it is a great implementation by Michael. I already use it with shortcut and it is such a great addition to Moi. That workflow helps in many cases.
Show messages: All  1  2-11
