On static and dynamic display of dimensions ; and converting annotations to lines.
All  1-5  6-9
10990.6 In reply to 10990.5
Alrighty, all solved through a reinstall. Thanks !
And for what it's worth, two suggestions from there :
- The ability to copy-paste dim styling properties from one to another
- A way to convert from Screen Size to Model Units according to the way the dim is currently presented on screen.
10990.7 In reply to 10990.6
Hi Pior,
Yeah it might be cool if the number of model units that keeps the screen size of the annotation the same as immediately before changing the scaling mode were applied when changing from annotation scaling By Screen Size to By Model Units. In other words, if the annotation size on screen wouldn't change when changing mode. This would make it so that the By Screen Size mode could be used to get things close by zooming and then By Model Units could be used for finessing / locking things down.
- Peer
10990.8 In reply to 10990.6
Hi Pior,
At some point I'd like to add controls for this into the object properties dialog.
Until then I've attached a MatchAnnotationProps command that can do that job.
To use it, select the dim you want to modify, then run MatchAnnotationProps, then select the object you want to match up with.
Instructions for installing a plug-in here.
10990.9 In reply to 10990.8
Well, that's yet another excellent little addition ! Very useful, thanks Michael :)
Show messages: All  1-5  6-9
