Hi pior, the "Scaling" option is available in v4 but it looks like you have a customized UI that is kind of a mash-up of a MoI version 3 era moi.css file (which is why your dropdown controls have a strangely placed arrow) and maybe some pieces from an older v4 beta?
You are missing some other pieces of the v4 object properties dialog as well, it should look like this for annotation properties:
It looks like you are missing new UI stuff from the Sep-10-2020 v4 beta - http://moi3d.com/wiki/V4Beta#Sep-10-2020
It's probably from overwriting the final v4 UI files with older versions.
You can get a new download of the installer at https://moi3d.com/reinstall.htm .
> Is there perhaps a way to toggle the option without going through the UI ?
Nope. Well actually I guess you can set it through script as well but using the UI is the intended way.
> So I suppose that this goes back to question (1), on how to possibly set text scaling for dims and
> annotations to be by model units.
I would recommend to re-install MoI so you have the final v4 UI instead of the UI from an earlier beta version.
If you want a dark UI I'd recommend using the v5 beta, it has one built in.
> Is the current zoom factor at the time of export determining the equivalent Scaling that
> the DXF dims get written as ?
When you have "Scaling: By model units" set there is an additional "Height" field that is shown where you can edit the model units height.
