Looking for a clever way to connect disjointed sketch lines
 1-10  11-30  31-33
10957.31 In reply to 10957.30
Yes but its was just for take something and give the possibility in Aff 1 to fill anything...
I believe i can make something like this: Moi Export PDF "Project view 3D"
then reload this PDF inside MOi = i have a Plane of the visible wire!
General Trim by a Plane = i have each zone as a surface
Rest to find something who surrond each surface by a curve!
to be continue...
maybe this from the above! :)
Explode Move = free surfaces in the space
Select Edges and move them = I have only closed Curves !
UnMove
UnExplodeMove
Export PDF
here just export PDF for see if the closed curves works! :) (before the UnExplodeMove)
Filling in Aff 1 works now like a charme!
I believe i am near an easy process! :)
EDITED: 21 Jan 2023 by PILOU
Tips
Better if the original objects are Boolean Union and generator vertical line of Cylinder hidden
The complete easy final Process! :)
Of course each closed curve can be Style colorized and Named inside Moi!
for have directly named Layers inside Affinity V1! (no made here)
With this http://moi3d.com/forum/index.php?webtag=MOI&msg=3334.2
you can name automatically some Styles (so futur Layers) as you want
for have something more elaborated than "Default" following! :)
( Calque = Layer in French)
Intersection with a plane of the Imported PDF
else i have refound a Close Multiple Curves Command :)
https://moi3d.com/forum/index.php?webtag=MOI&msg=2752.1
EDITED: 22 Jan 2023 by PILOU
Show messages:  1-10  11-30  31-33
