Boolean Union with Mirror'd solids
All  1-4  5-7
10322.5 In reply to 10322.4
Dear Michael I have got a question.
After creating an object using commands loft, swipe, network, etc; control points are gone?
I mean when user presses "show points" he/she would not be able to see any points?
Is it possible to see some points after creating objects using those commands? (Like when you create a box and u still able to see its corner points after it's creation)
10322.6 In reply to 10322.5
Hi Psygorn, some info on control points in the FAQ here:
http://moi3d.com/faq#Q:_Why_does_show_points_work_for_some_objects_but_not_others.3F
A box is a special case where every edge in it is a natural edge of the underlying surface and that's why you can see points on it. When an object has a joined edge that is not a natural edge of the underlying surface then that's when you won't be able to show points since if you moved some points you would pull open a hole in what is supposed to be a joined edge. To turn on points in that case you need to use Edit > Separate to break pieces out into individual surfaces. You can always show control points for a single surface that is not joined to anything.
10322.7
Hello Psygorn and Michael,
Psygorn: That is exactly it! Thank you for taking the time to fix it. I appreciate it,
Michael: Thanks for the in depth response. I didn't see that the plane was skewed, and now I know how to check it with the orthographic views and zoom.
Show messages: All  1-4  5-7
