Boolean Union with Mirror'd solids
All  1-2  3-7
10322.3 In reply to 10322.1
Hi dodeqaa, it looks like some of your surface have a little bit of a slant to them instead of being directly in line with a world axis.
For example this one here:
If I zoom in a bit on a side view I can see the surface, if it was tightly aligned with the mirror direction it would only show the edge from the side and not some of the surface as well:
So the problem that creates with the booleans is that it's difficult to intersect surfaces that are barely grazing each other with overlapping surface areas.
= Michael
10322.4 In reply to 10322.1
So one way that will work for your case here is to draw a line down the y axis and use boolean difference to cut the 2 solids with that centerline and discard the pieces in the middle.
You should then be able to boolean union the 2 remaining pieces together. That helps because it avoids trying to generate an intersection between 2 surfaces that are just barely skimming over each other's surface area but slightly off.
10322.5 In reply to 10322.4
Dear Michael I have got a question.
After creating an object using commands loft, swipe, network, etc; control points are gone?
I mean when user presses "show points" he/she would not be able to see any points?
Is it possible to see some points after creating objects using those commands? (Like when you create a box and u still able to see its corner points after it's creation)
10322.6 In reply to 10322.5
Hi Psygorn, some info on control points in the FAQ here:
http://moi3d.com/faq#Q:_Why_does_show_points_work_for_some_objects_but_not_others.3F
A box is a special case where every edge in it is a natural edge of the underlying surface and that's why you can see points on it. When an object has a joined edge that is not a natural edge of the underlying surface then that's when you won't be able to show points since if you moved some points you would pull open a hole in what is supposed to be a joined edge. To turn on points in that case you need to use Edit > Separate to break pieces out into individual surfaces. You can always show control points for a single surface that is not joined to anything.
10322.7
Hello Psygorn and Michael,
Psygorn: That is exactly it! Thank you for taking the time to fix it. I appreciate it,
Michael: Thanks for the in depth response. I didn't see that the plane was skewed, and now I know how to check it with the orthographic views and zoom.
Show messages: All  1-2  3-7
