Fillet is not giving me any results
All  1-3  4-11
10260.4 In reply to 10260.3
Hey, thank you!
But what about the corners which I would like to be more rounded than the others? It seems there is no solution to that. I have to apply the same amount of fillet for all the edges. I wonder if there is a way around.
Let`s say I want this edge (marked red) to have a bigger radius. Any solution?
10260.5 In reply to 10260.4
Take a look to the Variable Fillets...but only during the building...not after closed the Fillet function!
http://moi3d.com/4.0/docs/moi_command_reference7.htm#fillet (scroll)
EDITED: 1 Apr 2021 by PILOU
10260.6 In reply to 10260.4
Hi merdock, yes you're correct there isn't any way to do that currently. I have an idea for enabling that in the future, by having "edge sets" that you can build up to specify different radius values for different edges. Currently you can make "point sets" for specifying the radius value at a specific point for variable radius fillet but there is only one edge set currently.
10260.7 In reply to 10260.1
I know it's not what you asked for, but this is a good place to drop this....
10260.8 In reply to 10260.7
Cool trick!
10260.9 In reply to 10260.7
Would still like to see dual controls added to blend some day...
Message 10260.10 deleted 22 Sep 2024 by BOOLEANO
10260.11
Hi merdock.
It can be done by creating 3 curves of the surfaces (1,2,3) then with partial Loft 1-2 and 2-3, but you have to know exactly what final result you want.
Then on surface 1 the holes with the green curves are cut.
Then the extrusions are made on surface 1, they are joined to the extrudes, and the fillets that you want are made.
Now it only remains to join the 3 surfaces and you will have a solid.
EDITED: 22 Sep 2024 by BOOLEANO
Show messages: All  1-3  4-11
