Is it possible to select one of the faces of an object and then scale it?
 1-3  4-23  24-32
10091.4 In reply to 10091.3
Select the 4 points
Call Scale 3D and as the video shows Click the face's center & a Point corner's face (in this order) and move your mouse...
10091.5 In reply to 10091.4
Also there is no edit frame when u select only one face!
U know the philosophy behind Moi is speed! So I wish it was doable only by selecting the desired face!
(show points + selecting 4 points is less speedy than selecting one face and using "edit frame"
10091.6 In reply to 10091.5
Yes but you don't select a face, you select 4 points of a face!
That is not the same! ;)
If you have only one face it would work!
But that is not your case : you have 6 faces "connected"
10091.7 In reply to 10091.1
Create Box.
Show points.
Select points on the face.
Scale the points.
EDITED: 17 Jan 2021 by WAYNEHILL5202
A variation without going to the Panel... :)
(you can enter scale directly to the numeric keyboard)
Method of Scale 2 clicks move mouse is more "artistic" with eyes appreciation ;)
EDITED: 1 Jan 2021 by PILOU
10091.9 In reply to 10091.6
But it is not just a face :-) also it won't work for some Geometries!
10091.10 In reply to 10091.9
Sure but result will be the same...and that is not working like this :)
ps You have taken "Thumb image" so not very readable - you must take "Full size"! :)
10091.11 In reply to 10091.5
Hi Psygorn,
The example being shown will only work if used on untrimmed surfaces. As soon as you have trimmed surfaces, it doesn't work like that anymore.
So no, MoI doesn't have direct editing if NURBS trimmed surfaces.
It can be shown how you can create an object that allows you to move points around, but i dont think that's really what you're asking for...
Whether that gets added in for a future release, is a question answered by Michael...
10091.12 In reply to 10091.11
ah ok :-)
I also have another Issue! when u select a face & a closed curve only Boolean->Difference is executable. but Merg doesn't work! is it possible to make it work?
Should I ask this question in a new thread?
For your last case you must use the Flow function! More cerebral...;)
With maybe some desagreaments :)
10091.14 In reply to 10091.9
Create the geometry
Extrude
Separate the solid.
Select the points
Scale the points
Select and rejoin the planes to a solid.
10091.15 In reply to 10091.13
:-) Dear Pilou, could you provide more info?
10091.16 In reply to 10091.15
You must return to my answer! :) (some problems with my recording)
About your boolean question you must post an image or better a 3 dm file !
And about all question always post minimum an image when it's for objects! :)
10091.17 In reply to 10091.14
Dear wayne hill, I knew a different method :-)
and tanx for sharing yours, However, this is not what I meant! I wanted to see if it is possible just by selecting desired face you could scale the selected face (either by selecting the scale button or edit frame) and see the effect on the object real time!
10091.18 In reply to 10091.17
All functions are not visible in real time!
For simulate that you must use the Nodal Elephant system by Max Smirnov
but it's some work more cerebral elaborated and time consuming! :)
10091.19 In reply to 10091.16
ok :-)
10091.20 In reply to 10091.19
In your case Merge will works with only a face + your closed curve! :)
Boolean Diff with this same Surface + Closed Curve will make a hole like expected in normal use (without Keep objects)...
10091.21 In reply to 10091.1
Hi Psygorn, so as shown above it is possible to scale a box like you want using control points. That is not a general solution for all models though because of how NURBS models work with an "underlying surface" that has trim curves on it.
There is some information on that here:
http://moi3d.com/faq#Q:_Why_does_show_points_work_for_some_objects_but_not_others.3F
A box is a special case where it has all untrimmed surfaces and all the underlying surfaces have matching control points along the trim edge boundary.
In the future I do want to allow transforms like scaling to be applied onto a face in a more general way. It is a pretty difficult area to implement though because it involves extending and intersecting neighboring faces with the transformed face. That's why it doesn't do it yet.
10091.22 In reply to 10091.21
So because of that it's generally better to construct your scaled result from the beginning from curves rather than trying to squish around an already created solid.
So for your half cylinder case above you'd do something like this using Loft between 2 profile curves to generate your shape directly:
I guess I should clarify my comment above about extending neighboring surfaces - generally in CAD there is an operation called "local face editing" where a face is transformed and the surrounding faces stay the same and extend to meet the new face. So for example a face that is transformed by rotation would give a result like this:
So that's different from what you are trying to do, you are looking to not just scale the face surface, you are also looking to modify the "side walls", the surrounding faces as well. That's not something that you can generally do with NURBS models because of how they are constructed with an "underlying surface" that has trim curves, see the FAQ link above for more description of this.
Basically once you have done some booleans then many of the edges in the resulting solid are trim curves on an extended underlying surface. The trim curves are on the surface but they do not necessarily align with the control point structure of the surface and so you can't really squish them around the way you would with a polygon mesh model.
In a poly mesh modeling program there isn't this concept of trim boundaries that can be internal to a surface, in a polygon mesh the control points of a face are the same as the control points of the edges. That makes squishing things work well in a poly modeling program, at a cost of boolean operations not working well. The "underlying surface" with trim curve system in CAD works very well for boolean operations because when you intersect objects the "underlying surfaces" remain the same and only new trim curve boundaries are created. With a polygon mesh when you do a boolean the surfaces get diced up into small fragments and get increasingly more messy and hard to manage.
10091.23 In reply to 10091.20
I know it works with one face! Is it possible to make it work on a face of an object? like the way I showed?
Show messages:  1-3  4-23  24-32
