Is it possible to select one of the faces of an object and then scale it?
 1  2-21  22-32
Use Show Points + the Edit Frame
or Show Points + Scale ;)
Edit Frame
Scale
EDITED: 1 Jan 2021 by PILOU
10091.3 In reply to 10091.2
Show points + scale doesn't work for me!
10091.4 In reply to 10091.3
Select the 4 points
Call Scale 3D and as the video shows Click the face's center & a Point corner's face (in this order) and move your mouse...
10091.5 In reply to 10091.4
Also there is no edit frame when u select only one face!
U know the philosophy behind Moi is speed! So I wish it was doable only by selecting the desired face!
(show points + selecting 4 points is less speedy than selecting one face and using "edit frame"
10091.6 In reply to 10091.5
Yes but you don't select a face, you select 4 points of a face!
That is not the same! ;)
If you have only one face it would work!
But that is not your case : you have 6 faces "connected"
10091.7 In reply to 10091.1
Create Box.
Show points.
Select points on the face.
Scale the points.
EDITED: 17 Jan 2021 by WAYNEHILL5202
A variation without going to the Panel... :)
(you can enter scale directly to the numeric keyboard)
Method of Scale 2 clicks move mouse is more "artistic" with eyes appreciation ;)
10091.9 In reply to 10091.6
But it is not just a face :-) also it won't work for some Geometries!
10091.10 In reply to 10091.9
Sure but result will be the same...and that is not working like this :)
ps You have taken "Thumb image" so not very readable - you must take "Full size"! :)
10091.11 In reply to 10091.5
Hi Psygorn,
The example being shown will only work if used on untrimmed surfaces. As soon as you have trimmed surfaces, it doesn't work like that anymore.
So no, MoI doesn't have direct editing if NURBS trimmed surfaces.
It can be shown how you can create an object that allows you to move points around, but i dont think that's really what you're asking for...
Whether that gets added in for a future release, is a question answered by Michael...
10091.12 In reply to 10091.11
ah ok :-)
I also have another Issue! when u select a face & a closed curve only Boolean->Difference is executable. but Merg doesn't work! is it possible to make it work?
Should I ask this question in a new thread?
For your last case you must use the Flow function! More cerebral...;)
With maybe some desagreaments :)
10091.14 In reply to 10091.9
Create the geometry
Extrude
Separate the solid.
Select the points
Scale the points
Select and rejoin the planes to a solid.
10091.15 In reply to 10091.13
:-) Dear Pilou, could you provide more info?
10091.16 In reply to 10091.15
You must return to my answer! :) (some problems with my recording)
About your boolean question you must post an image or better a 3 dm file !
And about all question always post minimum an image when it's for objects! :)
10091.17 In reply to 10091.14
Dear wayne hill, I knew a different method :-)
and tanx for sharing yours, However, this is not what I meant! I wanted to see if it is possible just by selecting desired face you could scale the selected face (either by selecting the scale button or edit frame) and see the effect on the object real time!
10091.18 In reply to 10091.17
All functions are not visible in real time!
For simulate that you must use the Nodal Elephant system by Max Smirnov
but it's some work more cerebral elaborated and time consuming! :)
10091.19 In reply to 10091.16
ok :-)
10091.20 In reply to 10091.19
In your case Merge will works with only a face + your closed curve! :)
Boolean Diff with this same Surface + Closed Curve will make a hole like expected in normal use (without Keep objects)...
10091.21 In reply to 10091.1
Hi Psygorn, so as shown above it is possible to scale a box like you want using control points. That is not a general solution for all models though because of how NURBS models work with an "underlying surface" that has trim curves on it.
There is some information on that here:
http://moi3d.com/faq#Q:_Why_does_show_points_work_for_some_objects_but_not_others.3F
A box is a special case where it has all untrimmed surfaces and all the underlying surfaces have matching control points along the trim edge boundary.
In the future I do want to allow transforms like scaling to be applied onto a face in a more general way. It is a pretty difficult area to implement though because it involves extending and intersecting neighboring faces with the transformed face. That's why it doesn't do it yet.
Show messages:  1  2-21  22-32
