3D with 2 sketch
10058.1
Hi
here a workflow to create 3D part with 2 sketch and intersect fonction.
( the second and third files are animated Gif file )
Thanks to Pilou for is help
Chri
EDITED: 13 Dec 2020 by CHRI
Size: 95.6 KB, Downloaded: 139 times, Dimensions: 666x826px
Size: 170.3 KB, Downloaded: 118 times, Dimensions: 1053x693px
Size: 300.6 KB, Downloaded: 119 times, Dimensions: 985x686px
Very clean!
10058.3 In reply to 10058.2
Hi
New example ( animated Gif )
Chri
Size: 204.3 KB, Downloaded: 102 times, Dimensions: 523x786px
Perfect!
10058.5 In reply to 10058.1
Hi Chri,
This is a clever process, I would not have thought of it, thank you for sharing! Using 2D curves to make 3D solids in this way is a little like reversing the Make2D and Make2D4Views commands. I continue to be amazed by the number of ways there are in MoI to create things!
--Larry
10058.6 In reply to 10058.1
WTF Michael!
Why are so much genius and useful things not NOT commented.
I had never thought about trying to Int-bool 2 Sketches and get such a result.
This is briliant christian!
Thank you for this nice HINT.
moi still suprises me ever and ever again.
@Michael:
when can we expect to throw our Money over to you for Relase4?
maybe i will update my Rhino5 to 7. i dont want to upgrade both programs @ the same Time.
10058.7 In reply to 10058.6
Hi Blackbird,
It's in the Moi Command Reference under :
Sidepane:
Construct
Boolean > Diff, Union, Isect, Merge
But Christian example really makes it stand out.
10058.8 In reply to 10058.7
Hi
Thanks to you, it's nice to share
It also helps Michael to promote his fabulous software.
Christian
Seems this will be a game's boy with the Isect function! ;)
10058.10 In reply to 10058.6
Hi BlackBird,
It is documented in the help file:
http://moi3d.com/3.0/docs/moi_command_reference7.htm#booleanintersection
Soon! I'm just fiddling with updating the documentation right now. I'll be putting out one last v4 beta that will be the same as the release version and it will have an extended expiration so you won't have to upgrade for a while yet.
10058.11 In reply to 10058.10
Hi Micheal,
yes you are right... my fault... Sorry
