Show messages: All
1-2
3-18
Hi Bruno,
You might be confusing "Named objects" (objects tab) and "Styles"
Named object could be considered as a kind of filter for quick selection.
Styles are closer to a layer system. New objects are created in the current style that you select by clicking on the color square.
Marc
Haha Michael was quicker !
I think I got it. It will take time coming from Rhino.
So Styles work as layers. Named objects...they filter...they could have different name under the same Style.
Ok...mmm I will thikn about it hahaha
thanks a lot!
Is it possible to add an element to a named object already created ? I named a curve 'profile' I want to add to 'profile' another curve.
Hi Bruno, yes layers are slightly different in MoI, it's a little more flexible where you can work with sets of objects either by using object names or styles in combination with each other.
It's not really that named objects filter differently than styles, they just work the same way as styles where you can use them to hide/show/lock/select a batch of objects in one action using the Scene Browser.
You can install a plug-in to make it easier to assign to an existing object name, you can find that here:
http://moi3d.com/forum/display.php?webtag=MOI&msg=3830.4
That usefull plugin is OVER 7 YEARS OLD AND WAS FOR V2
But it still works in V4 Dez17 :-))))
Assign Name script is not working in MoI4Dec11Beta. No object names show up in the popup. (Window 7)
This is the case for activating the script with either Shortcut Key, or with Max's customui.
Assign Name Dialog does not seem to work properly in either MoI3 or MoI4Beta. (?) (For MoI3, the popup screen works, but in the Dialog window in upper right screen, selection does not work. For MoI4, Names do not show up in the popup window, nor the dialog window at upper right.)
(Activated with Shortcut Key, or customui.)
Similarly for Assign Preset Name, and Assign Preset Name Dialog. (I have 4, (edit, make that 6, with preset versions,) varieties of assign name script.)
EDIT: The above (misleading) results are the result of having extra files, with incorrectly named extensions.
With correctly named files (including correct extensions), and without incorrectly named files (including no incorrect extensions),
AssignName and AssignPresetName seem to work correctly in MoI3 and MoI4beta.
Did you write "AssignName" into your shortcut? And not "AssignNameDialog"?
Hi Ralf,
I tried a lot of permutations, with the results posted :-)
I'm just posting to help with the "debugging" for V4.
Yes for sure :-)
But mostly the problems are on the Mac side...
I'm not able to repeat any problem with AssignName over here, also running Windows 7 with the Dec11 beta.
Can you please post a 3dm model file that doesn't work for you , maybe something in your particular names is important for reproducing the bug.
I also tested AssignPresetName and that worked fine for me over here as well. There are a couple of different versions of it, make sure to use the newer v3 one that uses the MoI filesystem functions for reading the text file in with the name presets instead of the original one which used an ActiveX component to do it.
Well, I have become very good at creating nonexistent errors:-)
(I was using simple squares and circles for testing, and ran some tests on another (work) computer too.)
Somehow in the past 5 years or so, I've acquired extra copies of the 2 .....dialog.htm files, which are incorrectly named
AssignNameDialog.js, and AssignPresetNameDialog.js. The extensions should be .htm.
Also present are the correctly named .htm files.
Also the PresetNames.txt file was not copied over to MoIBeta command folder.
I also have correct and incorrect versions for custom.ui, with _underline prefixes...
Supporting a zip of 3rd party scripts would be more work, and may have risks...
Maybe there could be a zip file of non-stock, non-third party, proven scripts?
Maybe a listing of the names of the good, valuable, third party scripts?
Then there are the "not ready for prime time scripts." :-)
I've figured out two of my mistakes, which are based upon the fact that for AssignName.js and AssignPresetName.js, their respective ....Dialog.htm do not use the same name as the .js script. Using customui also influenced the problem.
1. When writing scripts, I developed the bad habit of renaming two scripts at once, for example: somexscript.js and some_script.htm, renamed to say _somexscript.js and _somexscript.htm, or somexscriptSAVE.js and somexscriptSAVE.htm, which works fine when both the .js and .htm have the same name.
In the case of AssignName and AssignPresetName, the respective ....Dialog.htm file has a different name, so there is a 50% or so chance of naming the AssignNameDialog.htm file to say _AssignNamesDialog.js which is wrong, and causes problems when present.
2. The second error is that when using AssignName.js, the AssignNameDialog CANNOT be named _AssignNameDialog.
( the PresetNames.txt file also cannot have an underline prefix.)
My 3rd error was not copying PresetNames.txt to the MoI4Beta.
I think that I have been using the preview area of Windows (file) Explorer incorrectly as well...
Hi Brian, I'm glad you got it working now! Yes, renaming them might lead to mix-ups. I think Burr does have a .zip file collection of a whole bunch of scripts somewhere, let me see if I can find it. Ok I think this is it:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7841.6
I would like to have the possibility of layers and sublayers and so on, to organize big objects.
Hi Rudl, I'm thinking that there could be "folders" for that, hopefully to use in the Objects section of the Scene Browser as well.
Show messages: All
1-2
3-18
