418-437
438-457
458-477
478-483
P.S.: A tip: if your mesh is fully symmetrical, import and subdivide half the mesh into MoI, then mirror and join to a solid. It will save quite some calculation time, and enable you to import larger meshes with more polygons.
Message 6674.479 was deleted
Not essential but...
does it possible to have "Snap" when move segment during the SSplit ?
Hi I cannot get this script to run for the life of me I'm on windows 10 is there something I missing on the install? Goes into commands right for the SubDivbeta9?
Hi Dave, there are some instructions on how to install plug-ins here:
http://moi3d.com/faq#Q:_How_do_I_install_a_plug-in_script.3F
Some things to look out for - make sure you have unzipped it, you need to copy the contents of the .zip file into the commands folder, not the .zip file itself.
Then to trigger it set up a shortcut key with _Subdiv_beta9 as the command name.
don't forget the first "_" at the beginning of the name! ;)
you can have any upper or lower letters but not space in the name!
_subdiv_Beta9
_subdiv_beta9
_SUBDIV_beTa9
will work :)
418-437
438-457
458-477
478-483
