Show messages: All
1-2
3-11
Hi Chris,
> another question: is there a way to select the faces inside an edge loop? The edge loop
> is the boundary for the faces selection so to say.
Could you please show an example?
thanks I have those 2 scripts in use already.
Fill slection is a workflow from polygon tools. For example here:
https://www.youtube.com/watch?v=q1iARRbYCvg
https://www.youtube.com/watch?v=WRGN1BSqnfI
The edge selection determines the faces selection border. That is a very effective workflow since it makes selctions on complex objects very easy
Hi Chris, try the attached SelectFill plugin.
Instructions for installing a plugin
here.
You'll need to set up an edge selection first, like this:
Then when you run it, you need to pick a face:
And then only faces inside the same zone bounded by the edges should get selected:
Hope that was what you were looking for.
SelectFill.js
that is absoutely awesome! Thank you very much. You just accelerated my workflow tremendously!
not works ?
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/not_work.3dm
Hi Pilou, it doesn't work on your case there because those are independent surfaces not joined to each other.
If you select those surfaces and use Edit > Join to glue them together into a connected object, then it should work.
Excellent!
You can click any face inside the loop!
here the last (or the first depending of your point of view! :)
Yes it is a great implementation by Michael. I already use it with shortcut and it is such a great addition to Moi. That workflow helps in many cases.
Show messages: All
1-2
3-11
