Show messages: All
1-6
7-13
_ImportObj Open the specified file
Do you have a shortcut code?
like: script:moi.geometryDatabase.fileImportSubD( 'c:\\test.obj' );
Hi feirui445,
_ImportOBJ is a plug-in so first you need to install it, you can get it at Max's file archive page:
http://moi.maxsm.net/media/files/
Install instructions here:
http://moi3d.com/faq#Q:_How_do_I_install_a_plug-in_script.3F
Then for the shortcut key you would put in:
_ImportObj
Thank you. I want to press a shortcut key to open C: \ \ test obj,Use_ Importobj command, open directly without file dialog box
Hi feirui445,
That command script was not set up to do that so you'll need to make some slight changes to the command.
Open up the file _ImportObj.js and find line number 4 which has this:
var objPath = moi.filesystem.getOpenFileName( 'Import OBJ', ' (*.obj)|*.obj' );
remove that and put in this instead:
var objPath = moi.command.getCommandLineParams();
if ( !objPath ) objPath = moi.filesystem.getOpenFileName( 'Import OBJ', ' (*.obj)|*.obj' );
Then you should be able to give a command line parameter in the shortcut key, like this (no doubled \\ in this case):
_ImportObj c:\test.obj
Thank you.
The imported box does not change the shape of an egg. What's wrong with the code?
After I use three shortcut keys, the fault appears
Q: script:moi.geometryDatabase.saveAs( 'c:\\test.obj', 'NoUI=true;Angle=180;Output=quads' );script:moi.geometryDatabase.deleteAll();script:moi.geometryDatabase.fileImportSubD( 'c:\\test.obj' );
A: script:moi.geometryDatabase.saveAs( 'c:\\test.obj', 'NoUI=true;Angle=180;Output=quads' );
Z: _ImportObj c:\test.obj
Hi feirui445,
Do you mean you're pressing these 3 keys in sequence or are you using just the first one which already does an combined export and reimport?
Your 3rd key has:
The _ImportObj plug-in brings in polygons as planar faces in MoI, it does not apply sub-d smoothing. If you want to use the native MoI sub-d converter use this instead for your importing step:
script: moi.geometryDatabase.fileImportSubD( 'c:\\test.obj' );
Another thing which may be a problem is that by default Windows restricts programs from writing to the root c:\ directory so you might need to run MoI with administrator privileges for it to be able to write to that location.
Show messages: All
1-6
7-13
