 98-117
 118-137
 138-157
 158-177
 178-197
 198-217
 218-237
 418-425
Brian,
The html help file can be located in the NE directory tree.  No website required.
For the PC, this is where the html help file is located:
C:/Users/<username>/AppData/Roaming/Moi/nodeeditor/nodes/extensions/help.html
By 'launch', I mean to shellExecute the html to the browser to view.  Not launch a website location on the web.  Although that can be done as well as starting external programs.
Thank you,
Wayne
Hi Wane,
I am using the documentation/help/Info method of Karsten.
To get the respective Info button, each node would need to have his code added.  And a documentation file added to /EN.
The help/documentation files are located in nodeeditor/ nodes/ Documentation/ EN  (or FR for French versions).
I will study Karsten's method more closely.  It did not work the first time for me, which usually means I did something wrong.
Wayne
Hi Wayne.
I've used Karsten's "method" with mimic or cut or paste methods, and do not really understand anything.
Message 9581.162 was deleted
Hi Wayne,
For what it is worth, the contents of my two shortcut keys to invoke nodeeditor are as follows:
moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html?scheme=Light', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );
moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );
For the second shortcut I also used James "color" scheme, rather than the default dark nodeeditor canvas.
I'll have a look at your basicFunctions.js.
In the basicFunctions.js that I am using, appdata appears.  I have not had a problem with it, as far as I know.
var docupath;
if ( document.URL.indexOf("appdata") > 0 ) { docupath = document.URL.split("index.html")[0]+"nodes\/extensions\/Documentation\/"+lang.LANGUAGE + "\/"; }
					else { docupath = document.URL.split(/moi:\/\/(.*\/).*/g)[1].replace("ui","")+"nodes\/extensions\/Documentation\/"+lang.LANGUAGE + "\/"; }
The above code may have been from Karsten, (in a forum post.).  I cannot exactly remember...
On a different topic, I recollect that changing Languages had some sort of problem...(mentioned in the Forum.)
You fixed my problem.  It was the startup with "...index.html?scheme=Light" that was the issue.  The info panel is working on the original basicFunction.js code.   I will go back and delete my previous post.
Thank you!
Wayne
This is a proof of concept of a coloring Node in beta testing.  It uses a javascript to reduce the image palette to a few colors so the styles are manageable.   The ImgRGB node creates the styles, while the OutputRGB Node removes the styles not being used.  It has circle packing and fixed mode output.  Background colors are masked to focus on the circle packing main objects.
Seems very appetizing!
Hi Wayne,
The image circle packing looks great - this was under RHINO but no longer supported a node like this in MOI would be great.
Great work -
Hi Alex,
Ref:
https://moi3d.com/forum/index.php?webtag=MOI&msg=9581.128
Your post from above had me searching high and low for a circle packing routine.  The circle routine used on my program node is more of a pointillism.  A weighted voronoi or stippling code would probably be closer to what you are looking for with images.  The circle pointillism is great for vector graphic images.  That is why it is still in beta.  There is more that can be added to this node.
Thank you,
Wayne
Hi Wayne,
Thanks for looking into it - further development would be a great addon in the tool library for MOI.
Great work and thanks for contributing to its progression.
regards
Alex.
 connectPts Node
This node proposal would be analogous to and based on Michael's script found here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2749.56
Happy Easter Everyone!
New ExtendSrf Node release:
ExtendSrf is based on Michael Gibson's script:
https://moi3d.com/forum/index.php?webtag=MOI&msg=9747.7
Thank you Michael!
Copy the ExtendSrf.js to the directory:
C:\Users\<UserName>\AppData\Roaming\Moi\nodeeditor\nodes\extensions
I would like to thank James for helping out with testing.
This is great way to divide solids into faces and shrink spacing between.
Wayne
Edit: Updated node
A sort of ExplodeMove ?
More like an additive and retraction of the face edges without changing location.  Michael described it as a surface offset.
Excellent!
Hi All,
It is a bit of an unusual method, but using Wayne's new node,
and using a sphere as a starting point, it's possible to form a compound
curved surface of the shell of a chair.
Thanks Wayne for your most recent contribution.
I'm hoping that coding nodes is a good technique to staving off cabin fever,
& we are it beneficiaries.
https://www.instagram.com/nodeology/Image Attachments:
That's magical thing!
 BranchStructure node
The proposed node would generate venation patterns from seed points branching out to leaf points (attractors) using the "space colonization" algorithm.
Daniel Shiffman has done a coding challenge that serves as a good introduction to the method:
https://www.youtube.com/watch?v=kKT0v3qhIQY
Another good resource is Jason Webb's "Modeling organic branching structures with the space colonization algorithm and JavaScript" :
https://medium.com/@jason.webb/space-colonization-algorithm-in-javascript-6f683b743dc5
He demonstrates the difference between "Open versus closed venation" which is an option I have include in the info panel. The other option I have included is 2D vs 3D. 3D would work similarly, however with branches attracted to leaf points in 3d space, making possible the generation of natural forms such as tree, coral etc. This may be something that is left for later development.
 98-117
 118-137
 138-157
 158-177
 178-197
 198-217
 218-237
 418-425
