158-177
178-197
198-217
218-237
238-257
258-277
278-297
498-503
Hz is for Hertz, the frequency or cycles per second.
In other words, the speed of the clock, or the speed of the twisting.
In general terms, a frequency of 1 hertz means that something happens once a second, but in the
nodeeditor program, the speed may be faster or slower. So it is the relative speed.
Examples:
Hz = 0.1 is slow twist...
Hz = 5 for faster twist...
The frequency could be measured, but may vary depending upon computer?, software load? etc ?
OK ...as i seen no notable difference with little or more bigger numbers i was perplex!
Thanks for the explanation!
On my computer, your excellent quartz/twist node runs slow at HZ = .1, and runs
rapidly at HZ = 1 or 2...
Maybe computer speed makes a difference?
Thx for precisions!
Just for say that i made a little more better UI for directly access to the Nodes! :)
http://moiscript.weebly.com/biblio-elephant.html
French done, English half done (will be finished this evening! :)
just test Quartz who seems indispensable for make animation!
Hi Pilou
How did you create this? Looks awesome.
Sorry my speed example above was not very raffined! :)
This other one following not many more but for explain the concept that is very sufficient!
Something like that...draw anything (here a simple box) out of the origin for avoid to manage the center et voilĂ :)
I don't want imagine that is possible to do! :D
Really funny and very speedy to do! Beauty of the simplicity! Small is beautiful ! :)
Ok as promised French/ English sweet UI Native Nodes is done for accelerate accessibility ! :)
Maybe i will make also a graphic Nodes Clickable...as i have now the "anchors" ;)
Not exactly each Native Nodes one by one clickable but... :)
(French / English)
http://moiscript.weebly.com/all-nodes.html
Can you validate the process for make such sort of thing!
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/easy.nod
Progression seems also indispensable for integrate some numerous data for create some sequential profils etc...if you don't want drawing first outof the Node then Select them...but maybe you have anothers strategy ?
As I use only "Native nodes" for the moment there is no "Scale" directly for the objects! (for the points yes if am i right)
Another thing : does it normal that the "Save" of the "Nodes" don't save the objects selected ?
I have found many things but not this very trivial!
now i have visible this in movement - that is curious because my previous example seems make that!
1
2
3
4
3
2
1
i want visible in movement
1
12
1234
123
12
1
So how draw in up and undraw in down ?
i have refound it how to make that! :)
edit : sorry for the disturb!
So from now i can make some funny things with a minimum native nodes! :)
Maybe a last difficulty will be to find a variating axes changing inside the object at each step for thing like twist, rotation etc ...
Some headaches but i find something for have the Twist axis dependant, semi dependant of any transformation! :)
Maybe i re-invent the wheel but...as i am very new on this sport ...that is making a good training for me! :)
As Twist is some time consuming (no real time) so no Quartz for this time! :)
A little fun...
the flow would be this one:)
Copy Macros that you have somewhere : 30 seconds if you have well organized files....
drawing a circle: 5 seconds....
calculation: 5 seconds
rendered: 3 seconds in your favorite render engine (mine free one: Simlab composer Maxi 1920*1080)
So one minute when not awake! And the programs not open! :)
An informed eye will of course see that the number of polys at the save was a little insufficient so 3 seconds more of paremetering! :)
A moi3D model by nodes ELEPHANT in the fabulous free TwinMotion !
After a little fun i restart a new long way! Will be very long because all these nodes are not all very easy ! (for me :)
The Extension Nodes !
http://moiscript.weebly.com/biblio-elephant.html (structure is in place - just to fill it now ;)
I will begin by the more easy : the Construct2 :)
Node Sweep
First perplexity who is double!
What is sequence P abcabc - aabbcc ?
What is the last line NumPts? Seems there are not the Numbers of Profils' Pts (become 3 for the "star") seems not the number of sections --- ???
Edit: a miracle! - there is a documentation for the Extention Sweep node inside the extensions file !!!
So seems my 2 questions are resolved! :)
Even better the Info is inside the Node Sweep itself by Right Click on the Node!
(I am affraid that is not the same for the other extension Nodes! There is the Info but it's empty for the other nodes! ;)
Clicking Info open this on the Node Editor!
Sorry for the Subliminal Asus publicity! :D
The Sweep node Information available by Info selection, was created by Karsten, here:
https://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1377
I made a few posts shortly thereafter.
The sweep.html is in the EN subdirectory of nodeeditor.
Other language versions would be located ???, and accessed by ???
I had some problem with access in light nodeeditor, but see that the info works in James light version, so need to review the situation.
As far as I know, nobody has written any .html info file for the other nodes.
Documenting the documentation...
Hi Pilou, just to make sure your question is answered:
That would only have an effect if the Profiles option is set to NumPoints mode. There is some information in the help file about the profiles option in the Loft command reference here:
http://moi3d.com/3.0/docs/moi_command_reference7.htm#loft
@Michael
I have seen that from the help inside : Num Points - has only an effect if NumPoints is chosen under Profiles. It defines the number of points used to rebuilt the profile curves.
I will make some tests for confirm the result because i am not sure to have seen that on my first try :)
@ Bem I am supposed to make a sort of help documentation of each node in this repository! :)
Of what i understand myself ! ;)
And also in French of course! :)
I see only 3 points against 24 asked! :)
But maybe it's not possible to see them ...maybe used only for calculate ???
And funny that a circle will be not more a circle at the "end" of the sweep with number of pts like 24...
158-177
178-197
198-217
218-237
238-257
258-277
278-297
498-503
