Full Version: Wall Panel - Houdini Apprentice -> MoI
Show messages:  1  2-21  22-41  42-61  62-75
25 Mar 2019   [#42]
About ZSurf Texture --> Nurbs
If you have no need to specific modify the volume and only render the volumes
just use SimLabComposer Lite! it's accept iges format! ;)
Else from my little texture above
Of course Moi3D can easily make something like this! ;) (make an array vertical lines then use Boolean Merge)
@Michael :can you integrate inside "ExplodeMove" an 1D, 2D direction for the V4 ?
For the moment here we must use distribute ... with 1D Scale ;)
http://moi3d.com/forum/index.php?webtag=MOI&msg=8503.17
Of course if you want each piece as a volume make a general box first and not just a surface like above before the Boolean Merge!
25 Mar 2019   [#43]
Hi PaQ,
your DistanceToPoint set-up is pretty awesome!
My first try with an imported .iges file from MoI. :-)
(I show the backside, because it looks imho cool)
Hope I can post soon some ideas, with your
file and MoI.
penrose
25 Mar 2019   [#44]
So many possibilities with PaQ's set-up … (where is that PayPal donate button :-))
I tried with a high grid setting (1024x1024) and used a Mandelbrot outline, which
I had created long ago with MoI.
mandelbrot
25 Mar 2019   [#45] In reply to [#44]
Super cool result Stefan !
I havn't invented anything here, I just lean it from this site :
http://www.tokeru.com/cgwiki/?title=Houdini
http://www.tokeru.com/cgwiki/index.php?title=JoyOfVex
25 Mar 2019   [#46]
Houdini is a bottomless well ! :)
25 Mar 2019   [#47]
Hi PaQ,
o.k., but you share your knowledge with pretty cool examples,
which I, as a Houdini noob, would not come up with nor find
the required resources easily. ;-) So, thanks for that!
25 Mar 2019   [#48]
O.k., after a second try I had to render this Mandelbrot, to better see how it would look
like as an image. Looks a bit like chocolate … :-)
Mandelbrot
25 Mar 2019   [#49]
I am always amazed by the funny result of all that! (only ZSurf + SimLab Composer Lite) and test with Moi for accelerate the process of Download!
25 Mar 2019   [#50]
indeed amazing what can be done. I am very glad that PaQ contributed so much valuable
infos and presets to this thread, which can open for us now new possibilities!
BTW. When looking at your image i think we can prepare with ZSurf (only using black
and white images, no greyscale) and MoI cool outlines for the set-up PaQ provided to
us. I.e. meaning once we have the Zsurf surface in MoI we simply trim it at a certain
position to get a nice edge, copy and paste it to have the outline … :-)
25 Mar 2019   [#51] In reply to [#50]
Moi is the Swiss knife! ;)
25 Mar 2019   [#52]
26 Mar 2019   [#53]
About GAEA - fresh air! a free version is existing! ;) (technology of the French SketchFab is some amazing!
(of course in Full screen on your biggest monitor = pleasure of the eyes!)
Gaea Biome Hero Image
by quadspinner
on Sketchfab
Gaea - Color Test 33-958
by quadspinner
on Sketchfab
Gaea - Erosion Test
by quadspinner
on Sketchfab
26 Mar 2019   [#54]
@PaQ
Best regards
26 Mar 2019   [#55]
Re-rendered this guy, to get rid of the chocolate look … :-D
panel3-Mandelbrot
26 Mar 2019   [#56] In reply to [#55]
beautiful
26 Mar 2019   [#57]
Thank you!
26 Mar 2019   [#58]
Picked some closed curves from an old MoI project and run it also
through PaQ's set-up, with a grid setting of 1024x1024, which then
shows the curves nicely.
panel5-spirocurves2a
26 Mar 2019   [#59] In reply to [#58]
the PaQ's set-Up is only for Houdini for be sure ?
27 Mar 2019   [#60]
Yes, only for Houdini.
27 Mar 2019   [#61]
you can try to do the same with ArtForm and the function "Region Relief",
once you have imported the curves and defined them as new model.
