 20-39
 40-59
 60-79
 80-99
 100-119
 120-139
 140-159
 200-218
This is correct - when typing the scripts they will be found.
But they do not appear in the selection box.
The change in the moi.ini did not bring any improvement.
-moritz
Hi Moritz, the "selection box" is not a built in part of MoI, it's part of the CustomUI extension.
So first thing to check is are you running an old version of that? You can get the current one from here I think:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.268
Hello, Michael,
now I have adjusted everything so far, but now I get the following hint when starting Moi
Where is this report stored so I can send it to you?
-moritz
Hi Moritz, actually the report generation for those cases (called an "assert" instead of a crash) isn't hooked up in v4, I'll re-enable it for the next beta.
There may be some information about it in the log though, you can show the log by running this script:
script: moi.ui.createDialog( 'ShowLog.htm' );
Could you please run that copy any text in there and send it to me here or e-mail to
moi@moi3d.com  ?
Thanks,   - Michael
here is the hardcopy (can't copy the text) of this log file
-moritz
Hi Moritz, thanks for posting that. That one means it can't find one of the "ui", "commands", or "docs" folders inside the normal app package (inside Contents/Resources inside the app).
Did you possibly delete one of those from your installation?
   -  Michael
Hi, Michael,
yes, at first I deleted these folders, but then reinstalled MoI. Now it also finds the commands folder in the library directory and the scripts run perfectly. Don't ask me what I did wrong - without your help I would be lost.
Thank you very much for your always quick help ...
-moritz
No problem moritz, I'm glad you are all set up ok now!
Message 9266.88 was deleted
Nodes from Elephant ?
Message 9266.90 was deleted
Message 9266.91 was deleted
Ah yes the  Dog-bone and T-Bone corners for your previous post ;)
Else for the offset lines
You can also close by 2 Blends it's more natural :)
But sure it's not automatic for hundred of them! :)
Hi Vladimir,
> Is there any way to automate this kind of rounding of two-dimensional geometry?
Try the attached InsertCircle script, it will insert a circle into your 2D shape with every click which places the circle's center point.
Instructions for installing a plug-in
here.
It works like this:
Hope that helps!  - Michael
EDIT: 5/29/2021  - added "Flip" option.
 InsertCircle.zip
InsertCircle.zip
Funny!
When you click out the space of the closed curve clicked for draw other circles
then that make Union with existant ones!
A sort of blobbing ogre! :)
(inside or outside)
And you can select several closed curves!
And you can change size during the drawing directly to the numeric keyboard!
Bones! ;)
French Version
http://moiscript.weebly.com/insertcircles.html
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/insertcircle_vf.zip
Message 9266.95 was deleted
Hi Vladimir, sorry I don't understand quite exactly what you want it to do. I was thinking you just wanted a quick way to place circles onto a rectangle with some different variations.
It sounds like you were looking for something more specific than that?
Is it that you want to generate the whole shape including the rectangle in one step? What parameters would you want to give?
Message 9266.97 was deleted
Hi Vladimir, in order to automate something I would need to know what parameters you want the automation process to take as inputs.
Would the input be the rectangle and 4 circle curves like you have in the file?
@Vladimir
Only for a quadrangle or for any closed curves ?
For many objects in the same time ?
 20-39
 40-59
 60-79
 80-99
 100-119
 120-139
 140-159
 200-218
