 15-34
 35-54
 55-74
 75-94
 95-114
 115-134
 135-154
 215-218
Hi nameless, both of those are definitely on my radar for future work.
I have what I hope will turn out to be a good idea for displaying warning messages at the end of a command, I'm eager to experiment with it after v4 is settled down.
*squeals with excitement*
Hello, Michael,
Thank you very much for the new update.
Unfortunately, I couldn't find my externally saved scripts in the script selection so far, although they are stored in the correct directory.
(/Users/moritz/Library/Application Support/Moi/commands). But when I call them manually, they work.
Also, when calling Max Smirnov's script "NutsAndBolts", I get the following error message.
Do you have any idea how I can fix the bug?
Thanks for your help
-moritz
Hello, Michael,
it works now with the version NutsAndBolts.v.0.96.2015.06.22
I have been using the version ... 21
Sorry for the inconvenience
-moritz
Hello, Michael,
The first problem still exists, although the entry in the moi.ini is as follows:
[Commands]
NonRepeatingCommands=delete undo redo
DoNotRepeatShortcutKeys=n
UseDiameterDefault=y
AdditionalCommandsDirs=//Users/moritz/Library/Application%20Support/Moi/commands
-moritz
Hi Moritz,
Could you please describe what you mean by "couldn't find" them ? If you type in the command name and it runs, that means MoI is finding them.
Hi Moritz,
> [Commands]
So the AdditionalCommandsDirs there isn't right, you've got it set there as a web URL. For a regular file name you'd want to have just one / at the start insead of // and have a space instead of %20.
But MoI will already look in that directory by default, so it should not be necessary to try and add it using AdditionalCommandsDirs, that's for adding more directories beyond the regular one.
This is correct - when typing the scripts they will be found.
But they do not appear in the selection box.
The change in the moi.ini did not bring any improvement.
-moritz
Hi Moritz, the "selection box" is not a built in part of MoI, it's part of the CustomUI extension.
So first thing to check is are you running an old version of that? You can get the current one from here I think:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.268
Hello, Michael,
now I have adjusted everything so far, but now I get the following hint when starting Moi
Where is this report stored so I can send it to you?
-moritz
Hi Moritz, actually the report generation for those cases (called an "assert" instead of a crash) isn't hooked up in v4, I'll re-enable it for the next beta.
There may be some information about it in the log though, you can show the log by running this script:
script: moi.ui.createDialog( 'ShowLog.htm' );
Could you please run that copy any text in there and send it to me here or e-mail to
moi@moi3d.com  ?
Thanks,   - Michael
here is the hardcopy (can't copy the text) of this log file
-moritz
Hi Moritz, thanks for posting that. That one means it can't find one of the "ui", "commands", or "docs" folders inside the normal app package (inside Contents/Resources inside the app).
Did you possibly delete one of those from your installation?
   -  Michael
Hi, Michael,
yes, at first I deleted these folders, but then reinstalled MoI. Now it also finds the commands folder in the library directory and the scripts run perfectly. Don't ask me what I did wrong - without your help I would be lost.
Thank you very much for your always quick help ...
-moritz
No problem moritz, I'm glad you are all set up ok now!
Message 9266.88 was deleted
Nodes from Elephant ?
Message 9266.90 was deleted
Message 9266.91 was deleted
Ah yes the  Dog-bone and T-Bone corners for your previous post ;)
Else for the offset lines
You can also close by 2 Blends it's more natural :)
But sure it's not automatic for hundred of them! :)
Hi Vladimir,
> Is there any way to automate this kind of rounding of two-dimensional geometry?
Try the attached InsertCircle script, it will insert a circle into your 2D shape with every click which places the circle's center point.
Instructions for installing a plug-in
here.
It works like this:
Hope that helps!  - Michael
EDIT: 5/29/2021  - added "Flip" option.
 InsertCircle.zip
InsertCircle.zip
Funny!
When you click out the space of the closed curve clicked for draw other circles
then that make Union with existant ones!
A sort of blobbing ogre! :)
(inside or outside)
And you can select several closed curves!
And you can change size during the drawing directly to the numeric keyboard!
Bones! ;)
French Version
http://moiscript.weebly.com/insertcircles.html
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/insertcircle_vf.zip
 15-34
 35-54
 55-74
 75-94
 95-114
 115-134
 135-154
 215-218
