4-23
24-43
44-58
About your first post for this object...
If they are not some "patch" or functions (Trim etc...)will be impossible... ;)
Else before some deformation cage :)
We "Separate" a surface (s) from a volume and we "Add points" to it (Edit Menu / Add Pts)
This makes it like a deformation cage where you just have to move the Control Points!
Points can only be added on one surface individually!
However, you can then move the Control Points from several surfaces at once!
Edit / View Points function activated of course! You can use the Edit / "Hide" and "Lock" functions
At the end, everything is grouped into a single "solid" volume (if the points of each adjoining face are "confused"!
For move points with some mirror effect with Scale function ;)
At first i create profile curves that lies exactly on rail curves.
But its not the main problem. The result shape looks messy.
> >Little skinny pieces are because of sharp corners not being aligned.
> How they should be aligned ? I checked all profile curves (except rails) to doesn't have tilt.
They should align by the curves touching each other at sharp corner areas.
Currently the closest points between your curves in that area is here:
So the generated surface is going to match up the closest points between those curves, and since that is not at the sharp point that will make a skinny fragment there when it additionally passes through the sharp area.
> I also tried to build them such a way so they touch rail curves with control points but it doesn't help much.
Touching control points is irrelevant, it's the actual body of the curves that would need to touch.
> And if you try to create tilt on a rounded corner part by trimming or extrude you lose roundness.
If you want your cut to have roundness you could build a rounded cutting surface using something other than extrude, like sweep. Then you'd fillet sharp edges to round them off.
But if the type of work that you want to do is similar to chipping away fragments of an initially blocky object while keeping everything smooth, that's really something more suited for ZBrush or 3D Coat's functionality. It's not a great fit for NURBS modeling.
Michael,
so if i understand it right there no need to create curve profiles so they lies with control point exactly on a rail profile.
You just need touch it somewhere(in other words you need intersection).
Mr. PILOU,
and there is no smooth operator plugin or script and no brushes for Moi right ?
Only click and drag points ? Maybe there is a grow selection script for points like we have for faces ?
Hi Bravlin, yes for the case of having sharp corners, the other direction curves should intersect with the corner location.
On other cases where there are not sharp corners it's usually ok for the curves to just come close to each other.
But that's just one issue - it's still just not going to work very well to try and build something like that out of one single network surface.
<< Smooth operator
I believe that a nurbs surface is by definition a "smooth" surface :)
If you want modify it use my method above or similar and use some moves of the Edit Frame with some Control Points selected
<< No Brush
I don't believe for the moment
<< Grow Selection
for the moment only for faces from Edge or Face by Max Smirnov
A radial selection will be a fine start ;)
Nice one ;) We still need to move control points to make surface smoother.
Something similar to smooth deformer in XSI or a brush that distribute parameter (smooth deformer weights) could be pretty helpful.
<< We still need to move control points to make surface smoother.
Maybe there is yet something with the Node Editor! Ask it on their thread!
https://moi3d.com/forum/messages.php?webtag=MOI&msg=7777.1
(but your are not on the Nurbs' spirit ! ;)
Hi Bravlin, often it is not feasible with NURBS to smooth things out using control point editing because of how trim curves and "underlying surfaces" work.
When you do a boolean operation, surface control points do not change at all, instead the trim curves on surfaces are what changes. Trim curves mark areas areas of a surface as holes and in a model with trimmed surfaces you generally can't manipulate surface control points without opening up a hole.
There is some illustration of that here:
http://moi3d.com/faq#Q:_Why_does_show_points_work_for_some_objects_but_not_others.3F
It's a very different type of structure than polygon modeling.
So that's why boolean great in NURBS and such a crap in poly modeling.
So the more NURBS-like approach is to build shapes like so ?
Create profile curves, extrude curved surfaces, manipulate points (in this example i
use flow as deformer to bend surfaces) to get shapes you want. And trim it in the end.
MQ_03.3dm
Yes you arrive to the Nurbs spirit!
Micro deformation is Polymodeling
Macro deformation in Nurbs modeling! ;)
Hi Bravlin, yup that is correct - with polygon booleans where there isn't any concept of an "underlying surface", things get fragmented into little bits pretty easily.
With NURBS modeling that doesn't happen or at least happens much less frequently and that's a major factor for why booleans with NURBS work well.
There are some other things too like it helps in many situations that NURBS can represent things like an exact sphere with one surface instead of lots of little pieces and then intersections between a sphere and a plane can be handled as a special case with an exact result.
The tradeoff is that trim edges do not necessarily align with the control point structure of the underlying surface and so you can't modify an object by pulling edge points around like you can in poly modeling except in special cases.
So that also means that if you're not using booleans in your NURBS modeling approach you are also not really leveraging the strongest area that it offers.
Q_04:
Hi guys. Got another question.
Today it's not about surfaces and shapes.
It's about proportions and scale. I have this kind of a bended shape. It was bent by "Flow" deformer.
Now it has become necessary to make this shape thinner. But if i use scale operator we lose src proportions of this shape.
I assume that Flow operator may help with it. But i can't understand which surface to use for such case.
I don't have src surfaces that i used for shape bending.
If scale operator can solve this problem i dunno how to use it right?
MQ_04.3dm
Hi Bravlin, it's usually best to do such edits on your unbent shape and then do a new Flow with your updated object.
It is possible though to do a kind of "scale from center path" operation with Flow, to do that you would make a Sweep of a line profile:
Along a central rail curve:
That will be the base surface for the flow. Then make a narrower sweep surface using a shorter line along the same rail, that will be the target surface for the Flow. An example result is attached.
MQ_04_2_3dm.zip
4-23
24-43
44-58
