201-220
221-240
241-260
261-280
281-300
301-320
321-340
361-372
Also does it only happen when you're using
https:// and not
http:// ?
Also the max size for an individual file uploaded as an attachment is 10MB, is your file larger than that?
There is also a limit of 50MB for all attachments, if you have a large file it is better to upload it to a file sharing service like Dropbox, etc... and then have a link to it here rather than have a very large direct file attachment.
vods for scripts that i've made
https://www.dropbox.com/sh/80jbog45r5k9hcu/AABQOif-bXD9QgLVgMYZAv3da?dl=0
move
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.219
offset
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.211
fillet, inset, shell, offset(Brep)
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.197
chamfer
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.217
isoCurve
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.213
add point extended scripts
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.258
~ loop _ExpandSelectionTangecy
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.195
~ grow edge loops _GrowSelectionTangecy
bool difference -
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.182
extrude -
trim -
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.171
rect3pts with center -
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.164
extend tangency
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.158
Union+Join
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.140
filter -
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.108
round corners rectangle
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.76 +
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.204
mirror x/y
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.75 +
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.11
polycut
usefull in combination with perspective script and
zbrush side snap
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.23
usefull
planar from 3 edges
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.73
Ohayo
Michael can u make last message as first one ? so It should be ~ pinned
another script
scale + s -> scale bbox
DoScale.js
Hi Tudor,
Sorry I'm not sure how to do that. I can put a link to the first one in the wiki resources page though, would that help?
Thanks, - Michael
I'll make a new topic just for scripts, here will be questions !
Message 8665.267 was deleted
ohayo
wanna ask about rotation - wanna do a to bounding box option on pressing hotkey
first testing on curves -> there's an option in v4 -> crv.planarFrame
tested - but it's shifts from bounding box -> gives planar frame but in another location
my questions ->
1. knowing 2 coordonates is it possible to make a frame ? accordigly to
http://moi.maxsm.net/ it needs 3 (as it is from bbox to frame)
2. if upper is true wich will be (z) knowing x & y, next hotkey for flipping axis ()
3. if they are other scrips for rotation ?
shortly what I desire (unify rotation with some extra)
r - rotate
rr - rotate + bbox (planar frame 2d)
rrw(rrs) - rotate bbox + increase/decrease by amount (2d)
rrf - rotate from bbox + flip axis (x/y/z)
rrfw(rrfs) - rotate increase/decrease by amount (3d)
rc - rotate copy
rrc - rotate + bbox + copy
ra - array
rra - array from bbox
Hi Tudor,
Well 2 points does not identify a unique frame, the 2 points can form a z axis direction for the frame but there is nothing that locks down the x/y axis directions to a single answer. Depending on what you need it can be possible to do something like the AutoCAD arbitrary axis algorithm (
link) where you take a fixed direction like the world z axis and use cross product of that and the z axis to produce an x axis.
If you want the 2 points to be an axis to rotate around, you could try the RotateAxis command or factory, that takes 2 points instead of a frame and then a rotation angle and the rotation will be around the direction vector between those 2 points.
Sorry I don't understand this one.
ScriptArray:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5595.18
RotateArray:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9710.5
RotateAndExtrudeFace:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8126.34
any plans for opensubd ?
an example
https://youtu.be/gzyO8S5FLUU?t=181
Hi Tudor, yes I do plan on supporting OpenSubdiv style edge weighting imported through FBX format.
Ohayo !
wanna ask about techincal aspects hiding behind cad modeling
what's the reason to have always a solid shape ? why can't be done a bool operation of a plane and a surface knowing the plane normals ?
I believe it's essentially for Print 3D : you must have a thickness different than "0"
so a solid and not a simple plane surface who can't exist in the reality! ;)
And some practical for know how cost some volumes of materials for building or what is the density of something! ;)
But in Moi you can make Boolean operations with plane, surface with thickness = "0" !
HI Tudor,
That's because MoI is designed to try and not behave differently depending on which direction an open surface happens to have as the "positive" normal direction.
The booleans are based on working with solids. If you are working on all surfaces you should use the Trim command instead of booleans usually.
ohayo
dragging points from a curve doesn't snaps to points of the same curve
Hi Tudor,
Yes, that's intentional to avoid having consecutive points get stacked up on top of each other too easily, such stacking degrades some of the mathematical properties of the curve and can cause problems.
ohayo !
have a rectangle, wanna draw a small chamfer - at a good zoomout.
Q: It impossible draw without disabling snapping ? i'm asking about an option for snap distance !
Trim
t - trim add point
s - trim single segment ( can crash if not selected from object that was separated, idk how to fix)
added
c - join curves after deleting unwanted segments
Trim.rar
fixed UnionJoin script
earlier opened surfaces where duplicating
UnionJoin.rar
Have you somewhere a repository of all your cool things ?
201-220
221-240
241-260
261-280
281-300
301-320
321-340
361-372
