Full Version: Lots of unkown
Show messages:  1-12  …  193-212  213-232  233-252  253-272  273-292  293-312  313-332  …
13 Oct 2020   [#253]
no control over twist, and ~ the countour that i need ~ misses the uv
testo.3dm
Message 8665.254 was deleted
31 Oct 2020   [#255]
any way that fillet g1-g3 could have a second slider for adjusting scaling*?
31 Oct 2020   [#256] In reply to [#255]
Hi Tudor,
There isn't any way to set that up now but I would I would like to give some attention to Blend in the future and that is one of the things that I would like to do. Bring it up again when the v5 beta is underway.
21 Nov 2020   [#257]
discovered smt new today !
if curves are mirrored & attach each other -> they can extrude a solid object without union ! neat !
24 Nov 2020   [#258]
hotkeys
add point
c - close curve
d - delete corners
AddPoint.js
25 Nov 2020   [#259]
Hi Michael, I've made gif vods of my scripts -> got error
The page was not displayed because the request entity is too large.
25 Nov 2020   [#260] In reply to [#259]
Hi Tudor, can you show a screenshot of the exact error message?
25 Nov 2020   [#261] In reply to [#259]
Also does it only happen when you're using https:// and not http:// ?
25 Nov 2020   [#262] In reply to [#259]
Also the max size for an individual file uploaded as an attachment is 10MB, is your file larger than that?
There is also a limit of 50MB for all attachments, if you have a large file it is better to upload it to a file sharing service like Dropbox, etc... and then have a link to it here rather than have a very large direct file attachment.
25 Nov 2020   [#263]
vods for scripts that i've made
https://www.dropbox.com/sh/80jbog45r5k9hcu/AABQOif-bXD9QgLVgMYZAv3da?dl=0
move http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.219
offset http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.211
fillet, inset, shell, offset(Brep) http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.197
chamfer http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.217
isoCurve http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.213
add point extended scripts http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.258
~ loop _ExpandSelectionTangecy http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.195
~ grow edge loops _GrowSelectionTangecy http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.195
bool difference - http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.182
extrude - http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.182
trim - http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.171
rect3pts with center - http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.164
extend tangency http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.158
Union+Join http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.140
filter - http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.108
round corners rectangle http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.76 + http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.204
mirror x/y http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.75 + http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.11
polycut http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.18
usefull in combination with perspective script and
zbrush side snap http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.23
usefull
planar from 3 edges http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.73
30 Nov 2020   [#264]
Ohayo
Michael can u make last message as first one ? so It should be ~ pinned
another script
scale + s -> scale bbox
DoScale.js
30 Nov 2020   [#265] In reply to [#264]
Hi Tudor,
Sorry I'm not sure how to do that. I can put a link to the first one in the wiki resources page though, would that help?
Thanks, - Michael
30 Nov 2020   [#266]
I'll make a new topic just for scripts, here will be questions !
Message 8665.267 was deleted
30 Nov 2020   [#268]
ohayo
wanna ask about rotation - wanna do a to bounding box option on pressing hotkey
first testing on curves -> there's an option in v4 -> crv.planarFrame
tested - but it's shifts from bounding box -> gives planar frame but in another location
my questions ->
1. knowing 2 coordonates is it possible to make a frame ? accordigly to http://moi.maxsm.net/ it needs 3 (as it is from bbox to frame)
2. if upper is true wich will be (z) knowing x & y, next hotkey for flipping axis ()
3. if they are other scrips for rotation ?
shortly what I desire (unify rotation with some extra)
r - rotate
rr - rotate + bbox (planar frame 2d)
rrw(rrs) - rotate bbox + increase/decrease by amount (2d)
rrf - rotate from bbox + flip axis (x/y/z)
rrfw(rrfs) - rotate increase/decrease by amount (3d)
rc - rotate copy
rrc - rotate + bbox + copy
ra - array
rra - array from bbox
30 Nov 2020   [#269] In reply to [#268]
Hi Tudor,
Well 2 points does not identify a unique frame, the 2 points can form a z axis direction for the frame but there is nothing that locks down the x/y axis directions to a single answer. Depending on what you need it can be possible to do something like the AutoCAD arbitrary axis algorithm (link) where you take a fixed direction like the world z axis and use cross product of that and the z axis to produce an x axis.
If you want the 2 points to be an axis to rotate around, you could try the RotateAxis command or factory, that takes 2 points instead of a frame and then a rotation angle and the rotation will be around the direction vector between those 2 points.
Sorry I don't understand this one.
ScriptArray:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5595.18
RotateArray:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9710.5
RotateAndExtrudeFace:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8126.34
14 Mar 2021   [#270]
any plans for opensubd ?
an example https://youtu.be/gzyO8S5FLUU?t=181
14 Mar 2021   [#271] In reply to [#270]
Hi Tudor, yes I do plan on supporting OpenSubdiv style edge weighting imported through FBX format.
2 May 2021   [#272]
Ohayo !
wanna ask about techincal aspects hiding behind cad modeling
what's the reason to have always a solid shape ? why can't be done a bool operation of a plane and a surface knowing the plane normals ?
