Full Version: Lots of unkown
Show messages:  1-7  …  188-207  208-227  228-247  248-267  268-287  288-307  308-327  …  368-372
30 Sep 2020   [#248] In reply to [#247]
Hi Tudor.
Ok!
13 Oct 2020   [#249]
Ohayo
will be possible to improve antialiasing on plane surfaces ?
13 Oct 2020   [#250] In reply to [#249]
Hi Tudor,
> Ohayo
Not for v4 but possibly at some point down the road.
13 Oct 2020   [#251]
Thnkas !
& I have one more modeling challange ! I was looking around moi todo it
It's a new year toy that has to be twisted ~~~ I gave up doing in moi
13 Oct 2020   [#252] In reply to [#251]
Hi Tudor, maybe try the Transform > Deform > Twist command for that. Something like this:
tudor_twist_toy1.jpg  tudor_twist_toy2.jpg  tudor_twist_toy3.jpg  tudor_twist_toy4.jpg
13 Oct 2020   [#253]
no control over twist, and ~ the countour that i need ~ misses the uv
testo.3dm
Message 8665.254 was deleted
31 Oct 2020   [#255]
any way that fillet g1-g3 could have a second slider for adjusting scaling*?
31 Oct 2020   [#256] In reply to [#255]
Hi Tudor,
There isn't any way to set that up now but I would I would like to give some attention to Blend in the future and that is one of the things that I would like to do. Bring it up again when the v5 beta is underway.
21 Nov 2020   [#257]
discovered smt new today !
if curves are mirrored & attach each other -> they can extrude a solid object without union ! neat !
24 Nov 2020   [#258]
hotkeys
add point
c - close curve
d - delete corners
AddPoint.js
25 Nov 2020   [#259]
Hi Michael, I've made gif vods of my scripts -> got error
The page was not displayed because the request entity is too large.
25 Nov 2020   [#260] In reply to [#259]
Hi Tudor, can you show a screenshot of the exact error message?
25 Nov 2020   [#261] In reply to [#259]
Also does it only happen when you're using https:// and not http:// ?
25 Nov 2020   [#262] In reply to [#259]
Also the max size for an individual file uploaded as an attachment is 10MB, is your file larger than that?
There is also a limit of 50MB for all attachments, if you have a large file it is better to upload it to a file sharing service like Dropbox, etc... and then have a link to it here rather than have a very large direct file attachment.
25 Nov 2020   [#263]
vods for scripts that i've made
https://www.dropbox.com/sh/80jbog45r5k9hcu/AABQOif-bXD9QgLVgMYZAv3da?dl=0
move http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.219
offset http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.211
fillet, inset, shell, offset(Brep) http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.197
chamfer http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.217
isoCurve http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.213
add point extended scripts http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.258
~ loop _ExpandSelectionTangecy http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.195
~ grow edge loops _GrowSelectionTangecy http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.195
bool difference - http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.182
extrude - http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.182
trim - http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.171
rect3pts with center - http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.164
extend tangency http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.158
Union+Join http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.140
filter - http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.108
round corners rectangle http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.76 + http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.204
mirror x/y http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.75 + http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.11
polycut http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.18
usefull in combination with perspective script and
zbrush side snap http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.23
usefull
planar from 3 edges http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.73
30 Nov 2020   [#264]
Ohayo
Michael can u make last message as first one ? so It should be ~ pinned
another script
scale + s -> scale bbox
DoScale.js
30 Nov 2020   [#265] In reply to [#264]
Hi Tudor,
Sorry I'm not sure how to do that. I can put a link to the first one in the wiki resources page though, would that help?
Thanks, - Michael
30 Nov 2020   [#266]
I'll make a new topic just for scripts, here will be questions !
Message 8665.267 was deleted
