184-203
204-223
224-243
244-263
264-283
284-303
304-323
364-372
Hi Tudor, you could make a post here in the forum and then link to the forum thread. Github is a good idea too though.
rectangle interactive
the idea is to combines all rectangles under one shortcut and switch between them from hotkeys
q rect
w rect center
e rect 3pt
r - will be added -
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.164 -> rect with 3ptcenter ~ another way to grow new rectangles
script is unfinished
rect_interactive.js
Hi Tudor.
Only one rectangle ;-)
looks a like a runtime error, I dont have it !
it's about moi version or smt else not related to the script
or it might ask for html .. that I havent work on, try to add if it works
rect_interactive.htm
Hi Tudor.
Ok!
Ohayo
will be possible to improve antialiasing on plane surfaces ?
Hi Tudor,
> Ohayo
Not for v4 but possibly at some point down the road.
Thnkas !
& I have one more modeling challange ! I was looking around moi todo it
It's a new year toy that has to be twisted ~~~ I gave up doing in moi
Hi Tudor, maybe try the Transform > Deform > Twist command for that. Something like this:
no control over twist, and ~ the countour that i need ~ misses the uv
testo.3dm
Message 8665.254 was deleted
any way that fillet g1-g3 could have a second slider for adjusting scaling*?
Hi Tudor,
There isn't any way to set that up now but I would I would like to give some attention to Blend in the future and that is one of the things that I would like to do. Bring it up again when the v5 beta is underway.
discovered smt new today !
if curves are mirrored & attach each other -> they can extrude a solid object without union ! neat !
hotkeys
add point
c - close curve
d - delete corners
AddPoint.js
Hi Michael, I've made gif vods of my scripts -> got error
The page was not displayed because the request entity is too large.
Hi Tudor, can you show a screenshot of the exact error message?
Also does it only happen when you're using
https:// and not
http:// ?
Also the max size for an individual file uploaded as an attachment is 10MB, is your file larger than that?
There is also a limit of 50MB for all attachments, if you have a large file it is better to upload it to a file sharing service like Dropbox, etc... and then have a link to it here rather than have a very large direct file attachment.
vods for scripts that i've made
https://www.dropbox.com/sh/80jbog45r5k9hcu/AABQOif-bXD9QgLVgMYZAv3da?dl=0
move
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.219
offset
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.211
fillet, inset, shell, offset(Brep)
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.197
chamfer
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.217
isoCurve
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.213
add point extended scripts
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.258
~ loop _ExpandSelectionTangecy
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.195
~ grow edge loops _GrowSelectionTangecy
bool difference -
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.182
extrude -
trim -
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.171
rect3pts with center -
extend tangency
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.158
Union+Join
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.140
filter -
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.108
round corners rectangle
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.76 +
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.204
mirror x/y
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.75 +
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.11
polycut
usefull in combination with perspective script and
zbrush side snap
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.23
usefull
planar from 3 edges
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.73
184-203
204-223
224-243
244-263
264-283
284-303
304-323
364-372
