182-201
202-221
222-241
242-261
262-281
282-301
302-321
362-372
Thx for the Info!
I was not enough perceiving! :)
ohayo !
Michael how can I add a script page to show last updates of scripts (remove history tabs) or better will be github ?
Hi Tudor, you could make a post here in the forum and then link to the forum thread. Github is a good idea too though.
rectangle interactive
the idea is to combines all rectangles under one shortcut and switch between them from hotkeys
q rect
w rect center
e rect 3pt
r - will be added -
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.164 -> rect with 3ptcenter ~ another way to grow new rectangles
script is unfinished
rect_interactive.js
Hi Tudor.
Only one rectangle ;-)
looks a like a runtime error, I dont have it !
it's about moi version or smt else not related to the script
or it might ask for html .. that I havent work on, try to add if it works
rect_interactive.htm
Hi Tudor.
Ok!
Ohayo
will be possible to improve antialiasing on plane surfaces ?
Hi Tudor,
> Ohayo
Not for v4 but possibly at some point down the road.
Thnkas !
& I have one more modeling challange ! I was looking around moi todo it
It's a new year toy that has to be twisted ~~~ I gave up doing in moi
Hi Tudor, maybe try the Transform > Deform > Twist command for that. Something like this:
no control over twist, and ~ the countour that i need ~ misses the uv
testo.3dm
Message 8665.254 was deleted
any way that fillet g1-g3 could have a second slider for adjusting scaling*?
Hi Tudor,
There isn't any way to set that up now but I would I would like to give some attention to Blend in the future and that is one of the things that I would like to do. Bring it up again when the v5 beta is underway.
discovered smt new today !
if curves are mirrored & attach each other -> they can extrude a solid object without union ! neat !
hotkeys
add point
c - close curve
d - delete corners
AddPoint.js
Hi Michael, I've made gif vods of my scripts -> got error
The page was not displayed because the request entity is too large.
Hi Tudor, can you show a screenshot of the exact error message?
Also does it only happen when you're using
https:// and not
http:// ?
182-201
202-221
222-241
242-261
262-281
282-301
302-321
362-372
