Full Version: Variable Width Line Offset Command - fatT Lines
Show messages:  1-4  5-24  25-44  45-51
28 Feb 2016   [#45]
Hi Max,
First : thank you for your many contributions very very useful !
I have a question about this script: Is it possible to add an option to automatically fill in the result of this "thick line" with a new custom style (black by default, like the boom in "dimensions" script) ?
To make " classic " technical drawing (no color) , we have several tools :
- "Hatch-it" script
- "Dimensions" script
- "Fatlines" script
For completeness, it should miss perhaps a tool for making drawn dashed . Maybe I can detail this point if it interests people other than me ! (https://en.wikipedia.org/wiki/Engineering_drawing#/media/File:Line_types.png)
Bear
29 Feb 2016   [#46]
This is great fun thanks guys
Can history be enabled ? if possible so if you change the base lines the output updates
cheers
shayne
28 Aug 2018   [#47] In reply to [#16]
Hi, how did you re import the subdivision model? I have yet to find a way to figure out how to import .obj's as simple as you make it sound.
T
28 Aug 2018   [#48] In reply to [#47]
As you export as OBJ from Moi
you can re-import the same File with ImportOBJ by Max Smirnov !
http://moi.maxsm.net/media/files/ (scroll)
30 Oct 2024   [#49]
Can be useful for architecture or other things! :)
Fat Lines support now multicolors : curves must disconnected and in different Planes!
By Michael! ;) https://moiscript.weebly.com/uploads/3/9/3/8/3938813/fatlines.v.0.7.2024.10.28.zip
If not you can make this little trick! ;)
Distribute your curves on Z http://moi3d.com/forum/index.php?webtag=MOI&msg=8503.17
Make Fat lines
Edit frame "Flat"
You can now Extrude your colored curves as you want!
And make any boolean operations!
All takes 3 seconds! ;)
28 Nov 2024   [#50] In reply to [#49]
hi pilou can you set the line widths to a specific width? e.g. 2mm or anything else a user may decide?
edit:
i presume that is setting the "larguer" slider shown in your earlier posts?
kindest...
28 Nov 2024   [#51] In reply to [#50]
Of course yes you can input any width !
Here 10 unities on 2 separated straigt lines
If you have several widths make several sets of lines (curves)
You will have a different result if you take connected lines! (here a polyline of 2 segments)
