Full Version: Variable Width Line Offset Command - fatT Lines
Show messages:  1-9  10-29  30-49  50-51
11 Sep 2015   [#30]
This is quite a useful script, is there any way to get this more integrated with the rest of Moi? -its basically offset curve on steriods. What I mean is for the offset to work using the snapping guidelines like fillet and chamfer instead of having to manually guess the width.
11 Sep 2015   [#31]
Hi Metin
Check the new version.
Today evening I'll play with different shapes.
11 Sep 2015   [#32] In reply to [#31]
That's really cool Max!
11 Sep 2015   [#33] In reply to [#31]
Pointy Fat Lines - Fun script Max !
11 Sep 2015   [#34]
Excellent!
11 Sep 2015   [#35]
Ps I have had a crash!
With the pointlines above
I recall the plugin then move the cursor Width then crash! :)
So load the file, Select all, call the plugin! (width with rectangle : Move the cursor several times ) Does it the same for you ?
Unexpected condition !
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/fat00.3dm
11 Sep 2015   [#36] In reply to [#35]
Yes, I've noticed crashes too. I'll make some changes to avoid them. this script is in early beta stage.
11 Sep 2015   [#37] In reply to [#36]
No problem, i am confident! :)
11 Sep 2015   [#38] In reply to [#37]
Hi Max & Pilou - re: Crash - I investigated the crash and it appears to be a bug in boolean union, where under some complex arrangement of curves it is possible for there to get a face (curve booleans internally happen on a planar face as part of their processing) that has no loops on it which is a degenerate condition and then other code that harvests the edge curves crashes when it hits that.
I'll be able to fix the crash by just skipping over this degenerate face with no loops rather than trying to access the loops on it, but that fix won't be available until the next public release of MoI and I currently don't know when that will be.
At the moment Pilou, I'd suggest not using the script on things that will yield chaotic results like you are doing here by trying to apply it twice in succession onto the previous results of it.
11 Sep 2015   [#39]
Pilou -
Your example above gives me an idea to experiment with Max's script to make Tribal Designs like these:
http://www.tattoo-bodyink.com/tribal-tattoo-designs/
Moving and sizing single curves to experiment is much easier than modifying closed curves.
11 Sep 2015   [#40] In reply to [#39]
Damn Ed, you are reading my mind! I thought the exact same thing-- use MoI to create tatoo work. I've been playing around with logos lately in MoI b/c it's easier to do things than Illustrator. Tatoos is a natural!
11 Sep 2015   [#41] In reply to [#40]
Exactly Chipp - Great minds think alike!
Yeah - Just lay down some curves and experiment. Much faster than modifying a design like that in Illustrator.
I cut designs into rings using a CNC milling machine, so you know where I'm going with this :) Just gotta go with the Flow.
11 Sep 2015   [#42]
Yes and can be also cool for rings! ;)
French version : http://moiscript.weebly.com/scripts-de-max-smirnov.html
11 Sep 2015   [#43]
The trick for fill them in case of Fat Lines curves 3D!
Separate then Loft! ;)
12 Sep 2015   [#44]
Hey, that's great Max, many thanks, much appreciated!
28 Feb 2016   [#45]
Hi Max,
First : thank you for your many contributions very very useful !
I have a question about this script: Is it possible to add an option to automatically fill in the result of this "thick line" with a new custom style (black by default, like the boom in "dimensions" script) ?
To make " classic " technical drawing (no color) , we have several tools :
- "Hatch-it" script
- "Dimensions" script
- "Fatlines" script
For completeness, it should miss perhaps a tool for making drawn dashed . Maybe I can detail this point if it interests people other than me ! (https://en.wikipedia.org/wiki/Engineering_drawing#/media/File:Line_types.png)
Bear
29 Feb 2016   [#46]
This is great fun thanks guys
Can history be enabled ? if possible so if you change the base lines the output updates
cheers
shayne
28 Aug 2018   [#47] In reply to [#16]
Hi, how did you re import the subdivision model? I have yet to find a way to figure out how to import .obj's as simple as you make it sound.
T
28 Aug 2018   [#48] In reply to [#47]
As you export as OBJ from Moi
you can re-import the same File with ImportOBJ by Max Smirnov !
http://moi.maxsm.net/media/files/ (scroll)
30 Oct 2024   [#49]
Can be useful for architecture or other things! :)
Fat Lines support now multicolors : curves must disconnected and in different Planes!
By Michael! ;) https://moiscript.weebly.com/uploads/3/9/3/8/3938813/fatlines.v.0.7.2024.10.28.zip
If not you can make this little trick! ;)
Distribute your curves on Z http://moi3d.com/forum/index.php?webtag=MOI&msg=8503.17
Make Fat lines
Edit frame "Flat"
You can now Extrude your colored curves as you want!
And make any boolean operations!
All takes 3 seconds! ;)
